MorphOS runs on QEmu
    Intuition
    Posts: 1110 from 2013/5/24
    ThePlayer wrote:
    Jim schrieb:
    I have no intention of buying anything as extreme as a threadripper cpu.
    Still, that's cool.
    A system that could potentially run MorphOS and OS4 sessions simultaneously.
    I guess an AMD Ryzen 1700 or 2700x should run this as good as the Threadripper. And this CPUs arn't that expensive.
    I will try it in two weeks when i am back from vacation on my Ryzen 1600 and Post some benchmarks.
    Is it possible to use the Networkstack in MorphOS on QEMU?
    Only when booting from the CD image. Once installed the OS freezes on boot up if you have networking enabled, no matter which emulated network card you use.
  • »16.07.18 - 09:00
    waldiamiga
    Posts: 91 from 2007/7/25
    Okay, I'm trying to run MorphOS ... Just for sport, but the Windows7 console being blown out spits me something like:
    d:EmulacjaQEmu>qemu-system-ppc -machine mac99,via=pmu -m 512 -vga none -device
    sm501 -cdrom morphos-3.11.iso -boot d -prom-env boot-device=cd:,mac_ppc32boot
    .img' -bios openbios-qemu.elf -serial stdio -net nic,model=sungem -net user
    C>> annot manage 'misc display controller' PCI device type 'display':
    >> 126f 501 (3 80 0)
    >> set_property: NULL phandle
    >> OpenBIOS 1.1 [Jun 27 2018 13:46]
    >> Configuration device id QEMU version 1 machine id 1
    >> CPUs: 1
    >> Memory: 512M
    >> UUID: 00000000-0000-0000-0000-000000000000
    >> CPU type PowerPC,G4
    milliseconds isn't unique.
    Output device screen not found.
    Trying cd:,mac_ppc32boot.img'...
    No valid state has been set by load or init-program
    0 >
    (qemu-system-ppc.exe:4328): Gtk-WARNING **: Could not load a pixbuf from /org/gt
    k/libgtk/theme/Adwaita/assets/bullet-symbolic.svg.
    This may indicate that pixbuf loaders or the mime database could not be found.
    Can anyone familiar with the topic write to me where the error is?
    [ Edited by waldiamiga 16.07.2018 - 13:12 ]
    MorphOS.pl
    Core i7 Notebook|WinUAE 3.x/AmigaOS4.1x & Icaros Desktop 2.x & QEmu 6.x.x
  • »16.07.18 - 12:05
    Posts: 2976 from 2003/3/5
    Use absolute paths to hd and cd images and perhaps try with -sdl.
  • »16.07.18 - 12:47
    Tested and played around a bit on a E5-1650 3.6GHz Xeon box and even with such a high end CPU it gives me sub-Efika speeds. Meh, won't run again.
  • »16.07.18 - 12:50
    Sub-Efika speeds, emulated SM502 graphics.
    I'd be willing to bet that this could be done better on Power9.
  • »16.07.18 - 13:10
  • Leo
    Leo
    Posts: 417 from 2003/8/18
    >> 126f 501 (3 80 0)
    >> CPUs: 1
    >> Memory: 512M
    >> CPU type PowerPC,G4
    0 >
    I am getting the same error on Windows.
    The same files work correctly on Linux & macOS.
  • »16.07.18 - 15:29
    Posts: 80 from 2017/9/10
    guys in the video im using morphos installed on img.
    the installation took really small time is really quick.
    use a raw as the image file ... dont make it more bigger than 10GB
    for boot the img is simple just swap the cd,\mac_soandso\boot.img in
    hd,\boot.img in the command line.
    the freeze or better the idle is because the lan . i think morphos try to go online form very beginning and this make all idle. just add -device rtl8139 without any other lan options.
    PS: there is a somewasre a crysalis pack iso complete for mos 3.11 without go online for download the packages?
  • »16.07.18 - 15:53
    dark_knight
    Posts: 11 from 2012/8/12
    Does it work in MOS 3.11? I recall reading that it had stopped working after the MOS 3.10 release.
    The latest version I can find is: https://www.warmup-asso.org/download.php?op=geninfo&did=1
  • »16.07.18 - 21:06
    Intuition
    These are the lame aksack.wav results on a 2.9GHz i7-4600M laptop.
    I'll test on my 7700k when I get a chance.
  • »17.07.18 - 09:26
    Intuition
    What results does the Efika get with lame aksack.wav?
    virtgpu support will eventually come and it'll pass through a Radeon card that will appear on the pci bus to MorphOS and use it's native drivers.
    QEMU-KVM doesn't work as yet so no running this on any PPC or Power9 without emulating it same as on x64 for now.
  • »17.07.18 - 09:30
    That won't help with a buggy and slow CPU emulation though.
  • »17.07.18 - 13:38
    Intuition
    Better than nothing at all though and it can only improve.
  • »17.07.18 - 13:52
    Posts: 1246 from 2004/2/8
    Intuition wrote:
    Call me stupid but which figure am I supposed to be looking at to compare it to this?
    http://sintonen.fi/pics/lame_benchmark.png
    I guess it's encoding time in seconds. Efika does the job in 2 minutes and 20 seconds (140 s). PowerMac G5 2,7 GHz encodes this wav in 8 seconds. Now for the screenshot you posted the situation is interesting. The real time differs from estimated by a very high margin (and on a real machine - it's never this way, as the "real" equals to "estimated" ultimately). I guess something isn't right with the timer under emulation. I'd probably go for the ETA number and a stopwatch just to be sure.
  • »17.07.18 - 14:16
    Posts: 12079 from 2003/5/22
    Regression with newer lame version? The graph shows 8 seconds for the 2.0 GHz PowerMac G5 and 6 seconds for the 2.5 GHz PowerMac G5.
  • »17.07.18 - 14:24
    Hmm... I looked at the numbers at AROS page. I guess it's time to do a final benchmark on my G5 machine to dispel the doubts.
  • »17.07.18 - 14:32
    It's 7 seconds there ;-) I assume there have been different lame versions/binaries at play (apart from AltiVec vs. scalar versions).
  • »17.07.18 - 14:49
    Andreas can you please link your lame version in case i will download it for make some benchs?
  • »17.07.18 - 15:08
    I guess this one was used. There are two versions in the archive: lame and lame_vmx (for AltiVec enabled machines).
  • »17.07.18 - 15:20
    > Andreas can you please link your lame version [...]?
    Sorry, I haven't used any lame version myself, but merely discussed lame benchmark results published by others.
  • »17.07.18 - 15:42
    I'd call it a lame excuse :rotfl:
  • »17.07.18 - 16:23
    Spectre660
    Posts: 275 from 2015/6/30
    Anyone know if KVM on an X1000 would work ?.
  • »17.07.18 - 17:02
