Posts: 418 from 2004/2/19
Tomjoad:
Sure
I gues you have at least a normal network conection
between both?
So you can either use a quick ftp conection (search aminet for rc-ftpd as a nice and easy to use ftp server) between both machines or you might try samba, which is afair available for the mac, for the peg the smbfs "file system" is enough if you just want to transfer the files from the peg (you are unable to see the drives under the Finder until you also have samba installed on the Peg)
Then there is netfs, which is also easy to use.
It is part of AmiTCP/Genesis, and should also be available for the Mac.
Samba for Amiga and the smbfs could be found
here
