Scumm VM 0.6.0
    Spidey
    Posts: 568 from 2003/2/24
    Just tried MonkeyIsland 1 and Zak McKracken with these versions.
    Unfortunately the same loading problem occurs.
    Bye,
    Spidey
  • »25.03.04 - 18:59
    Spidey
    I did have some problems running the MOS and WOS versions with Monkey Island 2 (I've got the 11 disk version).
    Saving is not a problem but loading just freezes the game.
    I tried the same with the 68K version and that works.
    Bye,
    Spidey
  • »24.03.04 - 21:13
    Spidey
    Hi tomjoad,
    I love Scumm!!!!!!! :-D:-D
    (had to say that)
    As you noticed, I corrected the not working games-part in the second post :-)
    You mention that MOS is now version 0.5.1, is that the version we can download from the Scumm website (it states 0.5.0, hences my question :-))
    Bye,
    Spidey
  • »24.03.04 - 21:10
    muckboy
    Posts: 47 from 2004/1/15
    amidi - Uses the MorphOS MIDI system, for MorphOS users
    What is this? Some internal midi driver of MOS?
    BTW: Does the MOS0.5.0 version run the CD-version of Beneath a Steel
    Sky (on the page mentioned earlier). It just crashed here, so I am
    wondering if someone got a trick to make it work :)
    PegasosII/G4@1GHz | 512MB PC2100 ECC/REG | Radeon9200/128MB | Seagate Barracuda 160GB@7200RPM
  • »24.03.04 - 19:48
    tomjoad
    Posts: 99 from 2003/2/24
    Well, I do allready have the 0.5.0 MOS version
    Last published MOS version was 0.5.1.
    but it does have a kind of a GUI. Maybe something to consider for ScummVM MOS 0.6.0?
    ScummVM features a launcher screen since IIRC 0.5.0 - it should appear automatically if you just launch it without any arguments.
  • »24.03.04 - 18:31
    tomjoad
    - The Secret of Monkey Island 1: doesn't work
    It does - use the PC VGA version.
    - Zak McKracken and the Alien Mindbenders: doesn't work
    You need the FM-Towns 256 color version.
  • »24.03.04 - 18:29
    Frostwork
    Posts: 302 from 2003/4/18
    Hi!
    I was able to play "Curse" till the end with the last MOS-port...
    At the beginning there was a problem with the cannons, but
    everything else worked....
    (as default Curse opens with some scaler-routine, which blows the resolution up to about 1280x1024 (or similar).
    There's a hotkey to deactivate this....
    bye
    frostwork
  • »24.03.04 - 13:55
    Posts: 889 from 2004/1/24
    @Dholm
    Oops :-) Well, I do allready have the 0.5.0 MOS version (dloaded it from somewhere else though), but I will give this one also a try. I have tried the WarpOS version, wich is version 5.1r2. Doesn't seem to work all that well (only managed to run DOTT; other games crashed rather hard) but it does have a kind of a GUI. Maybe something to consider for ScummVM MOS 0.6.0? Further more, the WarpOS version claims to run Curse of the Monkey Island...darn, if I only could find those cd's! Ah well, good excuse to clean out my room ;-)
  • »24.03.04 - 09:39
    Spidey
    Just read that all files need to be in the same directory, so I copied the files from the directory "Rooms" into the root-dir.
    Zak McKracken and Monkey Island 1 work now :-)
    But, no sound at the moment.
    Bye,
    Spidey
  • »23.03.04 - 22:00
    Spidey
    Hi everybody,
    I just downloaded ScummVM V0.50 MOS-version from that site (a TGZ-file) and also Beneath a Steel Sky.
    BASS doesn't work. SCummVM complains about the sound.
    I've also tried the following disk version games (just copied the files into 1 directory):
    - The Secret of Monkey Island 1: doesn't work :-(
    - The Secret of Monkey Island 2: Works :-)
    - Indiana Jones and the Fate of Atlantis: Works :-)
    - Zak McKracken and the Alien Mindbenders: doesn't work :-(
    The games that don't work have a different structure as the games that work. The working games are numbered from 000 to ....
    I've read that Zak McKracken does work. I'll go read again on the site :-)
    Bye,
    Spidey
  • »23.03.04 - 21:47
    Posts: 979 from 2003/6/28
    Beneath a steel sky and Flight of the amazon queen are freeware, so i guess that could be bundled ;-)
    These MorphOS version is the crap SDL version, why use these ####?
    One thing that i could like too is a launcher that can be added screenshots, the solutions/guides, various versions of the game on the same game section (by example, zak mackracken and the various versions, monkey island 1 and the various versions...)...
  • »23.03.04 - 02:48
    Ah, the Amiga version instead of the MOS version; have downloaded it and will try it right away -> thanx.
  • »22.03.04 - 21:03
    dholm
    Posts: 296 from 2003/9/1
    I use the one from the Amiga ScummVM site. The Curse of Monkey Island is still broken, I played that one in Linux using a CVS snapshot. The Dig worked perfectly in MOS though.
  • »22.03.04 - 20:35
    Hmm, that's strange; what version of ScummVM-MOS do you use? And did you mean The Curse of the Monkey Island? It would be gold to get that one running under scummvm
  • »22.03.04 - 19:50
    Yeah, same here (I was able to get out of the town before it crashed though ;-) ) and The Dig wouldn't even start, but hey, that's not a very good adventure anyway :-)
  • »22.03.04 - 15:32
    Estrayk
    Posts: 142 from 2003/12/30
    By the way, with the old version, Full Throttle and monkey 3 doesnt work very well here ! :(
    I hope tomjoad fix that too!
    Config: PegasosII G4/1000, 256MB DDR400, VooDoo 3000 AGP
  • »22.03.04 - 14:52
  • Targhan
    Posts: 2833 from 2003/2/8
    I'll get the files up here shortly. I wouldn't mind helping get the vale back, as I liked the layout and feel of the site as much as the software.
    :idea:Targhan
  • »21.03.04 - 19:59
    antibike
    Posts: 112 from 2003/3/5
    the site from tomjoad is unfortunately down ...
    so i cant give you a working link. the only thing we
    can to is to upload this lzx file to morphzone if
    tomjoad has nothing against this idea and targhan has
    enough webspace.
  • »20.03.04 - 13:54
    Donar
    Posts: 142 from 2003/12/27
    I have a .tgz here. Could you please point me to a place
    to Download the lzx file can't find it.
  • »20.03.04 - 13:49
    antibike
    why untar? the last archive 0.5.1 i have is a lzx.
    make your you have the executable flag set!!
    take a look with "list scummvm" ... if it is not set
    than type "protect scummvm +rwed"
    r = read
    w = write
    e = executable
    d = delete
  • »20.03.04 - 13:31
    Donar
    I have ScummVM Version 0.5 and 0.51 after untaring
    them i tried to start the ScummVM with a double click...
    does not work. In a shell typing ScummVM...does not work
    saying: file is not executable. execute ScummVM says: error
    in command name. What am i doing wrong???
  • »20.03.04 - 12:55
    Bladerunner
    Posts: 418 from 2004/2/19
    tomjoad
    Until easter??? *whaaah* don`t say that`s true.
    I am such an impatient person... ;D Ok I was
    just kidding, good luck with your contest :-)
    For VNC there is a vnc server for Amiga OS,
    AmiVNC
    But I have never tried it, don`t know if this works on MOS.
    The other defently won`t work, because it is a Picasso96 only thing.
    Nevertheless even if you have vnc running you still need of course a data connection.
  • »19.03.04 - 13:49
