Chrysalis Pack
    Brumiga
    Posts: 270 from 2004/4/3
    @Papiosaur,
    Here is my feedback after testing as requested.
    The installation goes well until the end but the exit window remains empty. I looked at the installation script of this beta version with that of version 3.17 and I found a small difference which explains the blank, run "wbrun lha >con: x -q". The -q is for 'quiet' do I suppose, it is not present on the previous version script.
    You still left the line with a loop in the user-startup to check if rexxsyslib.library has been renamed while the installation script carries out this renaming towards the end. Please remove this duplicate.
    You chose to install amissl but it is not used. After searching through Ambient I found 'amissl:' in 3 programs, rnoradio, rnowidgets and rnoxfer. Did the author, JPV, leave traces of amissl in the rnoradio code for morphos as well as in the rnowidgets code on amigaos 4.1, the same for rnoxfer on amigaos 4.1 and amigaos 3.x? The author should be asked to check whether traces of amissl are actually present in these 3 programs or not.
    Here are some ideas to explore before a final version of Chrysalis for MorphOS 3.18.
    Brumiga
  • »31.01.24 - 07:12
    Posts: 2207 from 2003/2/24
    None of these programs use AmiSSL on MorphOS anymore (and RNORadio never did). I've just made a generic download function that I use for all platforms, and it has an AmiSSL check for other platforms which leaves couple of traces on MorphOS binaries too.
  • »05.02.24 - 06:15
    NewSense
    Posts: 1576 from 2012/11/9
    You had left a space in the first "[url=_" section, so the linked file didn't work-trigger the download, as the address was incorrect initially, I have corrected this so the link now works. 8-D
    MacMini 1.5GHz,64MB VRAM, PowerBooks A1138/9 (Model 5,8/9),PowerMac G5 2.3GHz(DP), iMac A1145 2.1GHz 20", all with MorphOS v3.19+,Airport,Bluetooth,A1016 Keyboard,T-RB22 Mouse,DVD-RW-DL,MiniMax,Firewire/USB2 & MacOSX 10.4/5
  • »18.02.24 - 01:19
    Posts: 38 from 2023/3/27
    @Papiosaur
    Can we expect a final release or at least a new beta of your Chrysalis Pack for 3.19 soon?
    If not, I would like to use your last beta, but the download links are not working anymore...
    Either way, keep up the good work with all your projects :)
  • »29.04.25 - 05:34
    Papiosaur
    Posts: 2539 from 2003/4/10
    Hi Skygecko,
    thanks for your interest, sorry for the delay.
    I have many projets but yes, i must finalize it too.
    I must install new YouTube Extractor archive realized by Thomas Igracki, fix some problems on Easy2Install, and update some news (snes9.x, etc) and i release it.
    Brumiga has reported some problems to fix too.
    I try to finalize it before this week-end.
  • »29.04.25 - 06:02
    SkulleateR
    Posts: 73 from 2023/9/19
    Which weekend exactly  :-D ?
    No rush, just wanted to ask  ;-)
  • »13.06.25 - 17:09
    ChrisC
    Posts: 36 from 2025/3/1
    Thanks for the hard work Papiosaur
    Power Mac G5 11,2 Dual 2GHz
    ATI X1950 Pro 256MB
    2GB RAM
    500GB Storage
    MorphOS 3.19 (Licenced)
  • »14.06.25 - 06:32
    SkulleateR
    Papiosaur schrieb:
    Sorry for the delay :-)
    No need to say sorry  ;-)
    Thanks a lot that you do what you do for MorphOS  :-)
  • »14.06.25 - 07:05
    Tomtom76
    Posts: 41 from 2021/6/26
    Merci beaucoup :-)
    Powerbook G4 A1106 MorphOS 3.19 & MacOSX 10.4
  • »14.06.25 - 09:28
  • man
    man
    Posts: 136 from 2019/11/11
    Sur que le lien fonctionne?
    impossible de telecharger pour ma part
    merci papio tout de meme
  • »14.06.25 - 10:57
    agami
    Posts: 1 from 2026/3/16
    Is Chrysalis coming back?
    The link to the ISO is broken.
    Back to MorphOS,
    Now that I finally have a Power Mac G5 Dual 2.3GHz PCIe
  • »16.03.26 - 06:09
    Papiosaur
    Hello, sorry, the Chrysalis package is no longer maintained; it was outdated and causing problems. It has been replaced by Easy2Install, which allows you to create your own package.
  • »16.03.26 - 06:30
    NewSense
    @ Papiosaur - Did you retain in your archives on MorphOS-Storage the Chrysalis Pack's original Darker Blue Folders/Drawers/Directories as optional default icons for the system, as I always prefer those to any others, but they don't seem to pop-up when I do a search for icons via Easy2Install?  :-(
    Would have been nice to keep just one of the Chrysalis Pack's on MorphOS-Storage for anyone to download the files that you originally added to the Pack, so anyone could still add them to their system if they so wished to do so.  8-)
    I have kept a few of the Chrysalis Packs for my own personal use for that very reason.  8-D
  • »16.03.26 - 09:38
