Easy2Install
    kriz
    Posts: 310 from 2005/10/18
    Excellent stuff, glad to able to help abit :)
  • »01.08.23 - 20:54
    cip060
    Posts: 149 from 2010/7/30
    emulation section please FIX
  • »02.08.23 - 08:07
    Papiosaur
    Posts: 2555 from 2003/4/10
    @cip060: what is exactly your problem please?
    All archives are not "supported" for the moment... Thanks to read the readmefirst and expose me exatly what your problem is on my mail, it will be better to progress ;-) Thanks
  • »02.08.23 - 09:56
    cip060
    ONLY with EMULATION does this happen
    https://drive.google.com/file/d/1RqtEas_ccTzg7gza_BjLktG4OztI4_eL/view
    obviously then if I change the section the display always remains like this
    if I close and reopen the program it goes back to normal
    I made a thousand tests every time I choose emulation it is displayed like that
    I never add bugs from before various errors again
    I would also like to be able to click on the program name to sort them alphabetically or by program manufacturer
    [ Edited by cip060 02.08.2023 - 14:19 ]
  • »02.08.23 - 10:14
    Papiosaur
    @Cip060:
    As asked before, i need the software installed... All archives are not supported (as said before too).
    Thanks to (re)read the ReadmeFirst file please.
    Normally, you have a local version with 2 lines for a software installed (or more). I need to know which please to fix that, thanks.
    Sorry, i can't test all archives in a short time, i need a little help.
  • »02.08.23 - 10:34
    kriz
    A request for me would be to have a only download button, if you only want the file :)
  • »02.08.23 - 16:16
    Papiosaur
    I will try...but maybe it complicated to have the good name of the archive and i must propose a destination for this archive too...
  • »02.08.23 - 17:47
    kriz
    Sys:Downloads or similar default value would work for me, or assign download: maybe :)
  • »02.08.23 - 18:03
    Papiosaur
    it's easier than I thought, i will put RAM: by default and you could choose destination too ;-)
    I have added a bouton to open the application drawer too :-)
    Next beta soon.
  • »04.08.23 - 06:59
    kriz
    Ahh how great, keep up the great work @Papiosaur!
  • »04.08.23 - 08:22
    Papiosaur
    Hello,
    beta 28 available in the same link
    This is next features:
    - Abort button (maybe only for donwload process)
    - Create a directory if not exists
    - Rename drawer if had a bad name (name_mos for example)
    - Rename executable if had a bad name (name_mos for example)
    - Move executable if there is at a bad place (MOS drawer for example)
    - Fix the problem with filerequester
    If you have any ideas, don't hesitate :-)
  • »08.08.23 - 14:33
    NewSense
    Posts: 1592 from 2012/11/9
    @ Papiosaur - It would be good to have Ascending/Descending sorting on each of the columns, so if you were looking for some software with a name or date range of release in a category you couldn't remember the full name of or its release date, or some other reason then you might be able to find it easier, by arranging any of the columns in alphanumerical order, as I understand Hollywood can use this MUI feature. 8-)
    Also, being able to adjust the size of the images or reduce the section that they are contained in, in certain circumstances, such as when there is a long list of files to view that could take up almost all of the viewable GUI area, say with a 'balance' MUI gadget to make the file list area larger without having to resize the GUI frame, especially if you already have the GUI as large as it will open up to. ;-)
    Also, it would be good to have keyboard shortcuts for confirming to Quit/Exit - from the confirmation action requester "Do you really want to quit?" Yes or No option, so pressing Y would confirm Yes, and pressing N would confirm No. I appreciate you've already made it fairly easy to quit by focusing the default action 'Yes' as being that to Quit by only having to press the Enter key, with the alternative No requiring a press of the Tab key and then a press of the Enter key to confirm that action, or of course using the mouse pointer and a left click on whichever button is appropriate. 8-D
    MacMini 1.5GHz,64MB VRAM, PowerBooks A1138/9 (Model 5,8/9),PowerMac G5 2.3GHz(DP), iMac A1145 2.1GHz 20", all with MorphOS v3.19+,Airport,Bluetooth,A1016 Keyboard,T-RB22 Mouse,DVD-RW-DL,MiniMax,Firewire/USB2 & MacOSX 10.4/5
  • »08.08.23 - 21:24
    Papiosaur
    @NewSense
    Yes, i did some tests at the beginning but i had a problem with date format and the sort was bad. I have tried now and all seems ok now. Thanks to BeWorld to have changed this on the database!
    I have tried this too but with no success (i couldn't reduce the lister), i will retry and try to understand the problem.
    About this point, i have tried to add shortcut for the buttons but seems don't work proprely... i will investigate too ;-)
    Thanks a lot for your suggestions!
    [ Edité par Papiosaur 09.08.2023 - 07:49 ]
  • »09.08.23 - 03:48
    NewSense
    @ Papiosaur - I feel sure that jPV would explain the intricacies of the suggestions I made to you far better than most Hollywood users could, and I feel sure he would be prepared to do so for your program, as he has used these features in his own programs that he has written with Hollywood. 8-D
  • »09.08.23 - 16:08
    Papiosaur
    @NewSense:
    Yes, jPV has already help me on many parts on this project, i try to contact him when i need his help and he answer me each time.
    Templario help me too for a project with graphics.
    Beta-testers are a precious help too to improve this project ;-)
    [EDIT]
    GUI reworked a little, preview (fixed size in 320x256) take less place now and readme text is resizable in width with resize main window.
    I think is better like this.
    Balance object is possible for 2 objects "resizable", not possible in my GUI. I could down the buttons but i think it's not a good idea...
  • »10.08.23 - 06:31
    cip060
    Anything new on the horizon?
    New Beta Coming?
  • »13.08.23 - 07:00
    Mabo
    Posts: 67 from 2010/5/3
    Papiosaur wrote:
    Yes, i work on a button to "abort" download :-)
    Hi Papi!
    I was wondering if i should replace my old Grunch with your E2I.
    Can it damage my current os configuration? is it safe to use?
    Im back to this tiny os on my MacMini after years ;)
    Regards
  • »13.08.23 - 13:57
    Falcon_11
    Posts: 35 from 2004/2/7
    Hi Papiosaur
    Nice program.
    I don´t know, whether someone told you about this feature, or not. It would be good, if save position of Easy2Install window should be a same name. With every new beta version has own name and window is always in default position. Every time i need to save the new position.
    Thx
    Regards
    DEAD
    Pegasos-II
    Powerbook G4 A1139, MOS3.19
  • »15.08.23 - 18:37
    NewSense
    Papiosaur wrote: GUI reworked a little, preview (fixed size in 320x256) take less place now and readme text is resizable in width with resize main window. I think is better like this. Balance object is possible for 2 objects "resizable", not possible in my GUI. I could down (reduce) the buttons (sizes) but i think it's not a good idea... previeweasy.jpg
    Suggestion - How about an option to cause the ReadMe and Screenshot windows to be collapsed back into the GUI as a smaller button that could be clicked on to re-open them - as and when a user wants to see them, to allow the main GUI to display more files? 8-)
  • »15.08.23 - 22:09
    Papiosaur
    Falcon_11 a écrit :
    Hi Papiosaur
    Nice program.
    Thx
    Regards
    Hi Falcon,
    Thanks ;-)
    Yes, in fact it's a problem because the MUI prefs is linked to the version number and there are many beta version... I will try to found a solution for that. I don't know if i can specify a specific prefs file for MUI prefs with always the same name.
  • »16.08.23 - 02:20
    Papiosaur
    Hi NewSense,
    i have thank to "switch" this part too but to have more place on the desktop. I will see that too. Thanks for your suggestions to you and Falcon11 ;-)
  • »16.08.23 - 02:25
