Easy2Install
    cip060
    Posts: 153 from 2010/7/30
    I have problems using imac g5 isight
    when I change search by on the right side it happens that the font changes and the list that appears is one line yes and one line no
    like how the font changed
    sometimes it crashes and doesn't change the paths reloading the list as if the programs installed in my hardisk/ssd were not updated
    In any case great work for this program
  • »25.07.23 - 10:40
    Papiosaur
    Posts: 2625 from 2003/4/10
    ouuuch... do you have screenshots or video please?
    Maybe a problem with your SSD?
    Thanks to reinstall it on another partition or a USB key and retry please.
  • »25.07.23 - 12:27
    cip060
    https://drive.google.com/file/d/1RqtEas_ccTzg7gza_BjLktG4OztI4_eL/view?usp=sharing
    https://drive.google.com/file/d/1tv5_H1Rt488wNdFdK6pQjggcJCo6dpuY/view?usp=sharing
    https://drive.google.com/file/d/17ckPzFJTr7QU8oE5cMUUZpxfd70nfdmO/view?usp=sharing
    https://drive.google.com/file/d/1sIQS4-ojwQ72Iy7pbaqhIAoXGSde3GFz/view?usp=sharing
  • »25.07.23 - 14:20
    Posts: 2220 from 2003/2/24
    According to the last screenshot, it's a bug in the Hollywood code, which makes it to exit cleanly after an error, but it doesn't actually "crash".
  • »25.07.23 - 14:28
    kriz
    Posts: 314 from 2005/10/18
    I really like it !! Added to my desktop shortcuts, thx !! But is some software not availible for download, only weblink ? Like RNO Tunes ? Is there a system for this (for what got download links or not) ?
    [ Edited by kriz 25.07.2023 - 19:10 ]
  • »25.07.23 - 15:09
    Papiosaur
    Hi cp060,
    Thanks for the screenshots.
    Question: Do you have always this problem at each session of Easy2Install?
    What are the action do you realize please ?
    Select a category ? If yes, which ? etc.
    Seems Easy2Install don't find a version number during scan, i see this problem sometimes but Easy2Install finalize scan normally...
    What is the bug in picture 1.jpg please ? I don't see it.
  • »25.07.23 - 15:48
    Papiosaur
    Hi kriz,
    Thanks ;-)
    Sorry, i don't understand, "RNOTunes" is available in Audio section or by search by name :-)
    Normally all the archives from www.morphos-storage.net are installable via Easy2Install (same categories, etc.).
    You would like to have the possiblity to get the archive LHA?
  • »25.07.23 - 15:56
    cip060
    compare between photo 1 and photo 3
    as you see alignment between the lines there is some space
    this happens changing from demo /game network multimedia graphics do it several times and then it becomes like photo 3 and does not change anymore
    just by closing and reopening the program
  • »25.07.23 - 16:09
    Papiosaur
    This problem of space between lines could come from Easy2Install don't find the version number of an executable file of a software installed via Easy2Install...
    I have this error window "version has failed, error code 10" too with some software but i don't have problem of space between lines here...
    The software with version number problem must be resolved by the developer if possible.
    You can see a "not" string in Local column if there is a problem of version number.
    Say me what is the software have this problem and i will try to correct the problem.
    Command version send string: "Version not found" to Easy2Install instead the version number (executable 1.0)
    Maybe i can intercept error message...but i didn't how to do that...
  • »25.07.23 - 16:30
    kriz
    Check my screenshot. some are options greyed out for some software, i get like this for all when i search for mcc also ..
  • »25.07.23 - 18:01
    kriz
    Perfect, thx alot for the great work!
    [ Edited by kriz 25.07.2023 - 23:48 ]
  • »25.07.23 - 19:47
    cip060
    So when I search in the multimedia section and in the graphics section it ALWAYS crashes
  • »26.07.23 - 14:46
    Papiosaur
    Bizarre, no "crashs" here...
    What are the software installed via Easy2Install for these categories please?
    [EDIT]I'm fixing a problem with "Open" command when it don't found the good name of drawer.
    [ Edité par Papiosaur 26.07.2023 - 20:15 ]
  • »26.07.23 - 16:06
    Papiosaur
    jPV has help me to resolve the error message from command version when it didn't find the version number.
    It was the most important problem of Easy2Install, fixed now.
    The beta 21 coming soon with more archives supported and less problem from version number.
    Thanks a lot to jPV for his help!
  • »26.07.23 - 19:07
    Papiosaur
    Hello,
    New beta21 available:
    Easy2Install beta 21
    - error message from command version removed (thanks jPV!!!)
    - game/patch category fixed
    - new archives supported (see explanations in the readme file)
    - buttons states fixed after a search
    If some developers want to reupload their archives on MorphOS-Storage or send me on papiosaur2 @ hotmail.fr to be compatible with Easy2Install, you can of course (remove 68k version or other platforms exe / rename drawer / rename exe / change string version).
    The goal is all archives be compatible in a near future.
    To know if it compatible, Install Easy2Install, select your archive to test and select Install/Update.
    You can see readme of Easy2Install for more informations:
    Readme
    If you have any questions, don't hesitate to contact me.
    Thanks for your help ;-)
  • »27.07.23 - 07:46
    cip060
    nothing to do always crash when loading the list
  • »27.07.23 - 09:23
    Papiosaur
    Hello cip060,
    what is your "crash" please?
    i can help you and improve Easy2Install if you say me what are the software installed cause trouble.
    Maybe a version number of a software is showed with 2 lines instead 1 line and it create a space between all lines in the show of database but i need to know what is the software...
    Maybe it could be a problem with your fast memory, could you check it with "memtest" please.
    Don't hesitate to contact me on papiosaur2 @ hotmail.fr to report me your problems, it will be more easy.
  • »27.07.23 - 09:38
    A real crash (a hit in the MorphOS debug log) or Hollywood "crash" (program exits with an error requester)?
  • »27.07.23 - 12:31
    cip060
    still errors most of the time hollywood player error
    hurl.hwp error
  • »29.07.23 - 13:24
