Easy2Install
    cip060
    Posts: 151 from 2010/7/30
    Unfortunately in the games section the line jump has reappeared in the list
  • »06.10.23 - 09:42
    Papiosaur
    Posts: 2605 from 2003/4/10
    Thanks for your return, like before i need to know the game cause trouble please because there are many, many games... a lot of games are already supported but not all for the moment.
    What is the section please? Action, adventure, etc.
    Thanks for your return to help me.
    [EDIT]
    I have fixed:
    - RawGL
    for next beta.
  • »06.10.23 - 09:52
    cip060
    any news
  • »13.10.23 - 08:19
    Papiosaur
    cip060 a écrit :
    any news
    "What is the section please? Action, adventure, etc."
    @cip060 as already said, i need archives name make troubles...
    It's impossible for me to test all archives, i need help for that...
    I wait your answer to improve the support of archives make troubles.
    You can answer on this specific thread
    Thanks
  • »13.10.23 - 09:00
    cip060
    I was looking forward to a new beta thanks
  • »20.10.23 - 15:28
    Posts: 50 from 2020/10/11
    Papiosaur wrote:
    beta 39 available
    - added new banners (Wayfarer and Iris)
    - new archives fixed as stated in the IMPORTANT NOTE in ReadMeFirst.txt file
    - added more MUI Bubbles info
    - improved english texts (thanks NewSense)
    Thanks so much for your fantastic piece of software!
  • »20.10.23 - 16:18
    Papiosaur
    @Skateman: Thanks! I'm not alone in this project (see About window and ReadmeFirst)
    @ALL: Don't hesitate to return me if some archives are not supported (see ReadmeFirst for explanations), i will work on them for next release :-)
    Specific thread
  • »20.10.23 - 17:26
    cip060
    Then tried with all sections
    network and game shoot 3D I feel like messing up the list
    I've tried all of them and only these 2 are bothering me. The alignment of the files skips a line for each file
  • »21.10.23 - 15:23
    cip060
    UP
  • »26.10.23 - 15:27
    Papiosaur
    Hello cip060,
    you have already mentioned this trouble and i have already answered : "I NEED THE NAME OF ARCHIVE(S) CAUSE THIS TROUBLE".
    If i don't have this info, you will have to wait until I have tested all the archives...
    It's always a beta version for many sort of problems like this (thanks to read Readmefirst)
    Thanks to reread my precedent posts too.
    If i didn't have returns from users maybe Easy2Install will stay a long time in beta version for problems mentioned... each archive has a particularity...
    I hope you could help me to resolve your problems.
  • »27.10.23 - 05:43
    cip060
    archive name is this
    network and
    3D game shoot
  • »27.10.23 - 07:12
    cip060
    When I enter these sections it loads the list skipping the lines
  • »27.10.23 - 07:12
    Papiosaur
    Hello,
    Easy2Install beta 50 available:
    - fixed: some duplicated dates in the database
    - fixed: sort column dates prior to loading a new database
    - deleted installation drawer from RAM: if rescan is clicked on after an installation via an installer script
    - added open drawer command after extraction of archives with installer script
    - now after clicking on the "download archive" button or when you install an archive without executable, the destination drawer is opened in list mode to view the archive
    - added a new button to enable reporting a problem with any archives
    - use extended option of AREXX WRITE command from Iris (Thanks to Jacadcaps for this new feature), add string "WRITE %a %s %b" like OpenURL_Prefs.jpg picture to your OpenURL prefs in MorphOS Settings.
    Easy2Install 1.0 beta 50
    Thanks for your suggestions, tests and don't hesitate to report problems with archives if necessary.
  • »08.03.24 - 12:04
    Papiosaur
    Hello,
    beta 51 is available on morphos-storage.
    for information i have added a button to report if you have problems with some archives.
    Strangely, i don't have receive any mail :-)
    ps: beta 52 is soon available with german language, thanks to Jay Konrad for the translation!
  • »18.04.24 - 06:36
    Papiosaur
    Hello everyone,
    a new beta is approaching, don't hesitate to send your comments, bugs or suggestions ;-)
    Here is the list of next features/improvements:
    - reset the progress bar to 0 after reaching 100%
    - opening decompressed archives without executable in lister mode (with the open directory button)
    - added a “Launch application” button
    - fix for opening the directory for OpenSSL which did not work (thanks BeWorld)
  • »26.05.24 - 15:05
    Papiosaur
    Hello,
    i rework on Easy2Install.
    Don't hesitate to do suggestions for next release.
    Actual changes for next release:
    - added: an option to iconify Easy2Install after an installation (maybe for a download too) (not saved in prefs i think)
    - added: activation of the lister at startup to select an entry with arrow keys (thanks jPV for the tip)
    - fixed: version string for Stratagus entry
  • »08.05.25 - 08:01
    ppc-grinch
    Posts: 45 from 2025/7/17
    Easy2Install 1.7 released and I noticed that the design of the program changed to include new icons that are quite incongruent with the realistic 3D skeuomorphism of MorphOS's interface. In fact, I notice that many of Papiosaur's programs have shifted away from text buttons to these flat modern icon buttons, instead. At first I thought it was easier to use icons instead of translating text into languages, since icons are universal, but then I remembered that Papiosaur is already proficient in multiple languages, so it can't be that reason.
    I think many would prefer text-only buttons instead of these new icons, but, if Papiosaur insists on using icons in developing awesome software, then I might suggest much more appropriate and appealing icons that are free for anyone to use from the Unix/Linux/BSD world, like the Oxygen icon pack: https://www.iconarchive.com/show/oxygen-icons-by-oxygen-icons.org.html
    Or the Tango2 icon pack: https://commons.wikimedia.org/wiki/Tango_icons
    Or the Crystal Remix icon pack: https://github.com/dangvd/crystal-remix-icon-theme
    All three of these have no copyright. Though, I don't think anyone would chase you down if you took icons from Mac OS X, since a few programmers have done that for 3rd party MorphOS software already.
    [ Edited by ppc-grinch 03.06.2026 - 10:46 ]
    Mac Mini G4 1.5 Ghz, ATI Radeon 9200 64MB, 1GB RAM
  • »03.06.26 - 15:24
    Papiosaur
    @ppc-grinch: yes, i have changed text button by colored buttons, i think it more visual and better placed at top. I think the buttons are understandable and there are help bubbles too.
    Thanks to share this new buttons, i will see if i add them in next release.
    If someone want to changes the default button images he can. Just copy others pictures (.png) with same name and same size into Icons/ drawer.
    If someone want share a new sets of buttons to install in Easy2Install, he is welcome too. I wil add it if the look is good.
  • »04.06.26 - 06:39
