Easy2Install
    Papiosaur
    Posts: 2462 from 2003/4/10
    @jPV: yes, you have right but universal solution is a very hard because there many many version string format...
    Do you think an internal function to find version string will be more speed than the AmigaDOS command "version"?
    About support of space in name, i think it's not a good solution, it could make problems.
  • »22.09.23 - 05:16
    Posts: 2184 from 2003/2/24
    Probably not, I'd just try to parse the output from the Version command better (to tolerate line changes and whatever you might come up).
  • »22.09.23 - 11:11
    Papiosaur
    Thanks a lot for your help but format of version strings are very different from software to another software...
    Some examples:
    r2
    x.x
    x.x.x
    x.x.x.x
    xx.xx
    x.x.xgit
    x.xx.x
    x.xxx
    x.xbxx
    x.xx
    xx.x.x
    x.x.xx
    xx.xx.xxxx (date)
    xxx.xx.x
    xx.xxx
    x.x.x-x
    Sometimes the version string is empty...
    Sometimes command version don't found the version string...
    Sometimes the version string is not the version of the software...
    Sometimes i must use FULL option for commmand version, sometimes not...
    Sometimes the version string is on the first column, second, ...., seventh columns of the version string...
    I think a universal solution will be very difficult to do.
    I realize some "Case" to show the good version number...
    It's a long long processus but work when all is configured correctly ;-)
  • »22.09.23 - 14:20
    Papiosaur
    Hello,
    beta 36 available
    - new archives fixed as stated in the IMPORTANT NOTE in the ReadMeFirst.txt file
    - fixed a problem when the destination is "Ram Disk:" (thanks ghh)
    - fixed a problem when an archive is already present in RAM:T/
    - added the default path Sys:Demoscene/ for Demoscene category (thanks BeWorld)
    - improved english texts (thanks NewSense)
    Normally all archives from Emulation and Communication categories are supported.
    Easy2Install beta 36
  • »24.09.23 - 12:06
    cip060
    Posts: 146 from 2010/7/30
    the new version crashes immediately
    A very unstable real disaster
    everything I do stops
    I feel like crying
  • »25.09.23 - 10:27
    Papiosaur
    I feel like crying
    @cip060: Work fine here (for supported archives)...
    For you a crash, what is it please? A freeze, an error message?
    Maybe, install Easy2Install to another partition (no update on old beta)...
    You have last version of Hollywood plugins?
  • »25.09.23 - 11:12
    cip060
    Look, I've tried them all, I have experience on Morphos since the first 2.0 release for Macmini
    I have been buying and selling Amiga hardware for over 40 years
    incompatibility with imac g5 isight?? well who knows
  • »25.09.23 - 12:45
    beworld
    Posts: 664 from 2010/2/10
    I feel like crying
    @cip060
    Possible to have some log when app crash (LogTool, snoopium) maybe somthing on that? thanks
    I test here with clean install no problem with my iMac G5. (just need to install TextEditor and have a internet connection)
    Can you reinstall that: https://www.morphos-storage.net/?id=1901191
    PowerMac G5 Quad 2.5, IMac G5 2.1, PowerBook G4 1.5, MacMini 1.5
    My MOS ports
  • »25.09.23 - 16:24
    NewSense
    Posts: 1553 from 2012/11/9
    @ cip060
    beworld wrote: I test here with clean install no problem with my iMac G5.
    I too have an iMac 2.1GHz G5 20" system, and Easy2Install v1.0beta36 runs stably on my system as well, no issues of stability so far. 8-)
  • »26.09.23 - 00:19
    The most important thing to know (as Papiosaur already tried to ask) is how does it crash? Does it open a Hollywood error requester telling some information, or does the program or the whole system just hang immediately and you'll need a reboot?
    Does this mean that the whole system hangs? Even mouse pointer stops moving etc.? If this is the case, can you launch LogTool before launching Easy2Install to see if there would appear something? Maybe something MUI related which would indicated that Easy2Install might misuse MUI somehow?
  • »26.09.23 - 04:05
    cip060
    No, easy install just crashes, the rest of the system works
    it has a specific screen where the application opens not in the desktop
    This is the best I can give you in terms of guidance
    It also crashes when doing a simple refresh or scan of a directory
  • »26.09.23 - 07:21
    cip060
    No error message just hangs
    In any case the system works but remains in the background
    FIXED program screen
    [ Edited by cip060 26.09.2023 - 11:24 ]
  • »26.09.23 - 07:23
    What's in the MorphOS debug log then? When checked/saved for example with the Debug screenbar module.
  • »26.09.23 - 12:00
    Papiosaur
    Hello,
    beta37 available:
    - new archives fixed as stated in the IMPORTANT NOTE in ReadMeFirst.txt file
    - fixed "Open drawer" function for specifics archives
    - installation of TextEditor MUI class at startup if not present
    - fixed problem when log window was deactivated
    Easy2Install beta37
    Thanks for your returns
    [ Edité par Papiosaur 30.09.2023 - 22:53 ]
  • »30.09.23 - 16:11
    DJBase
    Posts: 745 from 2003/4/6
    Tried the frist time now, looks good so far but I have a lot of freeze.
  • »30.09.23 - 17:16
    Papiosaur
    Problem fixed.
    The application "stopped" when the option Log was not saved in state "deactivated" statute.
    Now the options are automaticaly saved when your active or desactive them.
    I have removed SAVE button too.
    Thanks to redownload.
  • »30.09.23 - 18:12
    cip060
    Excellent news, happy Sunday
    I'm trying beta 0.37
    I am very happy and satisfied I have been trying it for 1 hour (2 REBOOTS of morphos) 30 minutes unfortunately!
    No freezes or crashes and no changing font lines and line jumps!!
    You finally found the bug that was causing me all this trouble
    Compliments!
    Would it be possible to add an alphabetical order alignment of the programs by pressing on the names of the programs??
    It would be a perfect and very welcome addition
    Good day
  • »01.10.23 - 07:52
    Papiosaur
    @cip060: good news! i'm happy work better for you!
    There is always a work to improve it (i have found a error message, it will be fixed for the next beta)
    About an alphabetic order alignement, i will try to see that.
    Thanks for your return.
  • »01.10.23 - 08:15
    DJBase
    Hm, not sure what I am doing wrong or my PowerBook has issues but still getting freezes.
    Some examples:
    Starting Easy2Install, de-tick the Banner gadget -> Freeze
    Starting Easy2Install, de-tick the Preview gadget -> Freeze
    Starting Easy2Install, change "Search by" to "Last Entries", it reads and load -> Freeze
    Its a bit odd.
  • »02.10.23 - 06:26
    cip060
    DO NOT TOUCH ANYTHING EVERYTHING WORKS PRIVATE FOR 1 HOUR EVEN TODAY NEVER A CRASH
  • »02.10.23 - 07:08
    Papiosaur
    Some examples:
    Its a bit odd.
    Yes, bizarre... when you tick or de-tick Easy2Install save prefs to data/easy2install.prefs...
    Try to see with SnoopDOS or Snoopium what happen.
  • »02.10.23 - 07:45
    DJBase
    Well, it seems to be Skin Issue. I installed a fresh system, everything was working. I switched to Ater Skin and Easy2Install freezed the system. I switched back to Origo Skin and it was working again.
  • »03.10.23 - 12:45
    Papiosaur
    Thanks DJBase for the info!
    Ater and Origo skin?
  • »03.10.23 - 15:25
    DJBase
    Yes, Origo is the default theme in MorphOS. If I change Global MUI settings to Ater it will freeze the system.
  • »05.10.23 - 16:35
