    Posts: 1325 from 2010/1/6
    It's running now, but most videos will not be played......
  • »07.04.25 - 15:26
    Ah, OK - I'll try....
  • »06.04.25 - 19:37
    igracki
    Posts: 460 from 2003/2/24
    You only need the Hollywood Player v9, which is free.
    But sure, I can also upload a standalone version.
  • »06.04.25 - 14:03
    Looks impressive. ytSearch needs HW9. Is it possible to get a stand-allone compilation?
  • »06.04.25 - 13:54
    igracki
    Amigaharry2 wrote:
    @igraki/jacad: It would be very helpfull to integrate an easy call of YT-Extractor from Wayfarer. YT gets more and more strange - even AIOStreams does'nt work any longer.....
    I started to work on a Hollywood version of my ytSearch AmigaDOS script.
    It let you search for Youtube videos, displays them in a 5 column raster, a click on a video opens the yt.rexx script.
    It also still needs the rexx:YTS_ParseLine.rexx script from the yt.rexx archive.
    This may change in future, when I converted the YTS_ParseLine.rexx to Hollywood.
    The thumbs of the videos will be cached in t:Thumbs/
    Here is a preview picture:
    And here a video:
    ytSearch.mp4
    And here is the Hollywood Applet:
    ytSearch.hwa
  • »06.04.25 - 11:48
    Posts: 3210 from 2003/3/5
    CaptainBlood wrote:
    Could we hope for a drag&drop system to put a URL in the favorites bar?
    Currently busy with other projects and Wayfarer 10, but I'll try to look into that.
  • »05.04.25 - 15:27
    SkulleateR
    Posts: 72 from 2023/9/19
    Primax schrieb:
    Anyone also using Google Drive from time to time?
    If I try to dwonload a file, Wayfarer freezes :(
    Worked here some days ago but GD is (as youtube) slow as f**k regardless of the agent used :-(
  • »05.04.25 - 14:02
  • »05.04.25 - 05:44
    Primax
    Posts: 187 from 2021/7/2
  • »05.04.25 - 04:10
    Posts: 3 from 2025/3/16
    Hello all!
  • »27.03.25 - 12:46
    igracki
    I don't know how;) and what capabilities user scripts have.
    Is it possibie to add custom entries in context menus?
    Is there a documentation for Wayfarer user scripts?
  • »23.03.25 - 09:42
    igracki wrote:
    Do you have a link for a live video?
    Did you try it with the yt.rexx script?
    If you are in Wayfarer you just need to copy the yt url to the clipboard (with installed SmartClipboard.sbar) then the yt.rexx script extracts the video url and plays it with mplayer.
    Why don’t you make a user script for Wayfarer instead?
  • »22.03.25 - 21:40
    igracki
  • »22.03.25 - 19:09
    SkulleateR
    Primax schrieb:
    Has anybode successfully watched a live stream video on YouTube...?
    I tried it yesterday using the latest Wayfarer version and all the different spoofing options, but none of them worked.
    The video was stopping and I got graphic glitches etc.
    Any other experiences...?
    YT is very slow the last days and no, I cannot get any live stream working either ...
  • »22.03.25 - 14:29
    Primax
  • »22.03.25 - 05:44
    Posts: 12407 from 2003/5/22
    > falls Wayfarer eine AREXX-Schnittstelle hat, könnte
    > man das darüber an VPDF schicken und öffnen
    ARexx? Isn't forwarding of files something that MIME types should be used for?
  • »25.02.25 - 20:38
    Warum willst du eine PDF in Wayfarer öffnen? Dafür gibts doch VPDF.
    Noch mehr Funktionen in Wayfarer hineinzuquetschen macht keinen Sinn! Selbst die G5 kämpfen bereits ordentlich mit dem jetzigen Leistungsumfang - da sollte man nicht zusätzlich noch was draufpacken.
    Ich bin mir jetzt nicht sicher, aber falls Wayfarer eine AREXX-Schnittstelle hat, könnte man das darüber an VPDF schicken und öffnen (wer's unbedingt braucht...).
  • »25.02.25 - 20:12
    DanicaTalos
    Posts: 446 from 2010/10/15
    Amigaharry2 schrieb:
    Den Ausdruck auf "PDF" kannst du im Druckerrequester auswählen.
    Schade, dass man kein plugin oder ähnliches schaffen kann, dass diese Dokumente öffnen kann.
    iBook G4 - 14" -1,42 GHz - 32MB VRAM - 1,5GB RAM - 60GB mSata - MorphOS 3.19
  • »24.02.25 - 16:47
    ernsteiswuerfel
    Posts: 567 from 2015/6/17
    Ah yes, a1k-Login-Problem is fixed with Wayfarer 9.2. :-) Thanks!
    PMac G5 11,2. PMac G4 3,6. PBook G4 5,8. [MorphOS 3.19 / Adelie Linux / Gentoo Linux] | A600GS [Amibench / OS 3.2] | Talos II Secure Workstation. [Gentoo Linux]
  • »23.02.25 - 17:52
    DanicaTalos schrieb:
    Ich habe heute in Iris eine Mail mit dem PDF-Drucker abgespeichert.
    Da kam mir eine Idee.
    1. Könnte man so einen PDF-Drucker nicht in Wayfarer integrieren?
  • »23.02.25 - 14:56
    1. You can print/save PDFs from Wayfarer already. It's in the menu.
    2. It would make more sense to write a Wordworth/FinalWriter 2 HTML converter rather than integrate something into Wayfarer.
  • »23.02.25 - 13:23
    DanicaTalos
    2. Könnte man einen Dokumenten-Viewer für Wordworth- und Final-Writer-Dokumente integrieren?
    Dann könnte man seine Dokumente in den genannten Programmen schreiben und diese Dateien über Wayfarer entspannt als PDF konvertieren / speichern.
    Wäre eine Umsetzung möglich?
  • »23.02.25 - 12:32
    Quick as allways..... :)
  • »21.02.25 - 08:18
    Posts: 633 from 2004/4/15
    Woohaa!
  • »21.02.25 - 05:38
  • IKE
    IKE
    Posts: 150 from 2009/11/7
    Thanks Jaca!
    IKE
  • »21.02.25 - 00:32
