    Cool_amigaN
    Posts: 776 from 2011/11/30
    That would be awesome. If you could combine it with an optional setting where the user could select a (dark like Ater) MUI theme for the browser to accompany Dark Mode selection, that would be even better (plus the auto timing configuration perhaps).
    Edit: Eruda already has a theme selection for anyone interested (located on Eruda/Settings), which in combination with Ater, or a similar dark MUI theme give a very clean and stylish look for the browser :)
    [ Edited by Cool_amigaN 05.04.2021 - 00:22 ]
  • »04.04.21 - 18:47
    NewSense
    Posts: 1613 from 2012/11/9
    I was attempting to read the HHV (html) manual for PageStream v4 and v5 which I have done often using OWB v1.25, and with other versions of OWB, by using "Open file" menu option, but even though Wayfarer opens the file (softlogik.html) it fails to load the page with images and text, and the same occurs on subsequent pages of the HHV (html) manual.
    Has anyone else noticed or tested this functionality of Wayfarer and noticed this issue with other such manuals/older web/html pages?
  • »17.04.21 - 01:05
    Posts: 3321 from 2003/3/5
    Wayfarer 1.12 is now out! Get it from https://wayfarer.icu.
    Changes include:
    - Overlay based video playback
    - Experimental support for Media Source
    - Improvements in HLS playback
    - Other fixes and improvements
  • »17.04.21 - 13:33
    Posts: 1354 from 2004/2/8
    Yay! Does it mean YouTube video playback?
  • »17.04.21 - 13:59
    Piru
    Posts: 619 from 2003/2/24
    Yes it does youtube.
  • »17.04.21 - 14:10
    Hmm, are there any special tricks to make it work?
    I've copied the cgxvideo.library to LIBS: and checked the "Media Source Playback [EXPERIMENTAL]" in Settings/Media, but YT doesn't seem to like me. It says "You cannot play this video in your web browser. More information" :(
  • »17.04.21 - 14:15
    zukow
    Posts: 657 from 2005/2/9
    Direct video playing is also supported. Subtitles too, but who needs subtitles for pron :P
  • »17.04.21 - 14:18
    MoerBoer
    Posts: 239 from 2019/10/15
    I get the same thing. Copied the library, rebooted and getting the same error in YT. Even tried spoofing as Chrome, but alas.
  • »17.04.21 - 14:42
    beworld
    Posts: 672 from 2010/2/10
    Thanks Jaca and others membres MOSTeam !!
    @Kozer: Not LIBS: but MOSSYS:LIBS
    [ Edité par beworld 17.04.2021 - 18:45 ]
    My MOS ports
  • »17.04.21 - 14:44
    Zetec-s
    Posts: 198 from 2008/7/10
    Thanks to Jaca and all the rest of the MorphOS team, watching youtube and typing this right now on my G5 and the world is good!
  • »17.04.21 - 15:57
  • IKE
    IKE
    Posts: 150 from 2009/11/7
    Great news! Can’t wait to try it out
    IKE
  • »17.04.21 - 16:43
    Ah, OK. Now it works. Thank you.
    BTW, it's 'koszer' not 'kozer' :)
    The video playback is not perfect yet, but definitely a huge step forward. Great work!
  • »17.04.21 - 17:20
    Posts: 2217 from 2003/2/24
    BTW. videos do play without setting the MediaSource Playback too, and you might get less "experimental" experience then, but lose higher resolutions or so.
    And if you want to tune the quality of the playback, there's the Deblocking Filter setting to play with.
    [ Edited by jPV 17.04.2021 - 22:35 ]
  • »17.04.21 - 17:33
  • K-L
    K-L
    Posts: 46 from 2020/11/17
    Thanks !
    I copied the new cgxvideo.library to LIBS: and MOSSYS:LIBS (to be sure).
    I rebooted
    I launched Wayfarer
    I have activated the experimental media player in the prefs.
    ... And no video is played. I tried on YouTube and on PeerTube and still the same error messag : the video cannot be played.
    PowerMac G5 2,7 Ghz / Radeon 9650 / MorphOS 3.15
    AmigaOne X1000 (unused ATM)
  • »17.04.21 - 17:45
    Posts: 2090 from 2003/6/4
    I am quite impressed. On first testing quite a lot works: youtube really nice already. www.tagesschau.de and the mediathek of daserste.de, too. zdf mediathek, arte.tv or kika.de seem not to work as of yet. n-tv partially already. I think that is quite big already.
    Great job!
  • »17.04.21 - 17:49
  • K-L
    K-L
    Well,
    I tested everything I could, I checked that everything was set up correctly.
    I rebooted many times.
    And no video (and I tried a lot) is being played on my PowerMac G5 2.7 Ghz with a Radeon 9650 (MPlayer works without trouble).
    Any idea? Is it my system which is unsupported?
    Wayfarer 1.12 (17.04.2021)
    cgxvideo.library (in MOSSYS:Libs and also in Libs:) 43.18 (16/04/2021)
    I'm giving up for the moment, I spent a lot of time on this and couldn't play anything.
  • »17.04.21 - 18:53
    Posts: 1385 from 2010/1/6
    Same here! Cannot play any video (G5, Radeon9600). YT-pages are loading very, very slow and CPU is most of the time on 100%.
  • »17.04.21 - 18:58
    Well, both of you aren't providing me with much details here. What fails? Do you see a YT error screen? Does it show loading forever? If it's the former: I'll be releasing 1.13 soon which makes it possible to disable HLS that Youtube started feeding to people in some locations (I cannot get MPEG-TS to work yet, sadly). If it's the latter, there's a few things you can do:
    - open the Settings menu, go to youtube.com submenu and make sure 'Allow Media Playback' is enabled. reload the page
    - change spoofing to iPad in the same menu
    - press pause & play again
    - quit Wayfarer, go to Applications/Wayfarer/Cache, delete Curl, Storage, __IndexedDB folders, try again
  • »17.04.21 - 19:35
  • K-L
    K-L
    Thanks.
    Indeed, it shows loading forever (the rotating wheel on the play button).
    There is no "youtube.com" in settings (or I don't seem to find it), where is it hidden?
    I'll try to erase everything.
  • »17.04.21 - 19:57
  • »17.04.21 - 20:10
  • K-L
    K-L
    Ok, I see, my bad :)
    I had deactivated automatic playing with any site in Wayfarer.
    It's ok now.
    I have some trouble with https://video.triplea.fr (our peertube) : the files are not not played fully (only the firt seconds). Maybe the HLS thing you were talking about previously.
    A little thing I noticed : when in FullScreen on a YT video, left and right sides are truncated.
    Good work !
  • »17.04.21 - 21:03
    NewSense
    OK, so we've got some video displays now in Wayfarer - great work, major achievement for us all.
    On Formula1.com if I select a current page - Formula1.com - Lando Norris's Regret ... then I can load up the first video, as long as MSE and VP9 codec options are enabled, and I've tried just a few options in the "Deblocking filter" list to see if I can get a better video of that page.
    Initially I got a side-by-side video, a sort of Picture-In-Picture display, of the video squashed into the frame as though 2 versions of the video were running parallel to one another in sync/same time-frame, but with no audio. So, I reloaded the page and then got audio and video, though there was some stuttering (MacMini 1.5GHz) but more tweaking of the "Deblocking filter" allows better, more fluid/continuous - no/less stuttering, video/audio.
    However, on that page there is a second video of an interview of the driver, and it seems that once the first video/audio has been triggered it does not load up the audio or video for the second video without a complete reload of the page.
    I also cannot get a video to pause as such, the audio or video or both just keep running on, and then loop sometimes so there is little control over a video once it's been started, and you cannot play it back without a full reload, and the RAM gets eaten into in a big way for buffering the video, which doesn't release once a video page has been closed, some does but a large chunk of that RAM still remains locked into memory/RAM until the program is reloaded it seems.
    Others may have other observations on such features, but those are mine for the moment.
  • »17.04.21 - 22:58
    NewSense, a 1.5GHz mini is simply too slow for this website - it only serves 720p+ and no lower qualities. You're about 1GHz short.
    K-L, https://video.triplea.fr is trying to play HLS in JavaScript... I'll need to investigate what it does and what I have to do to make it work (if it's even possible). For now the focus is on YT.
    [ Edited by jacadcaps 18.04.2021 - 03:44 ]
  • »17.04.21 - 23:34
    NewSense
    @ jacadcaps - I initially could get the video to run OK on Formula1.com, in fact better in full screen mode, rather than in the webpage window and that's with the MacMini, so I got some good results for a too-slow system it seems.
    Anyway, after having to reboot, following Wayfarer failing to load-up after quitting to free-up system RAM I now get a system "error clang" when I try to load up Wayfarer v1.12 - which never happened with v1.11, and the videos just don't load, only the audio.
    Any idea what's gone wrong? Could it be something in the Wayfarer folders that is affecting it starting up correctly? :-?
    If I load up v1.11 as before I get it to load without any "error clang" it loads normally, and works as it did before, just no video playback.
  • »17.04.21 - 23:42
