Posts: 1476 from 2012/11/10
NewSense wrote: I haven't noticed any improvement in this regard with MUI, as my Active Tab still is not Highlighted using MUI Settings
jacadcaps wrote: What setting are we talking about? Tab colors look exactly the same between OWB and Wayfarer:
OK I'll send you some more debugs and screengrabs tonight to your gmail account - bear in mind you are showing your QEMU version of OWB and Wayfarer, and
Thomas Igracki - found/reported the same issue, so that issue is already corroborated by
Thomas Igracki, who is another well respected user/developer, with the TAB not highlighting through MUI Settings to make the Active Tab "
Active"- it's not just me that's reporting this issue. Not many people would consider tinkering with the MUI settings to achieve this improvement, but it's worth it as it highlights your active Tab, well it's supposed to, so you can easily spot the Active Tab if you've got a few that you are managing/have open at the time.
I am not aimng for one-upmanship points here, in any way, I am just stating that this is an issue, and it still needs addressing - when you fix it I'll be only too happy to say so - I am not trying to make things up for you to do, as I know you are very busy on our behalf, and I'm really grateful for all your efforts so far - I've already said so many, many times.
NewSense wrote: Oh, I noticed that if you try to save a Quick Link via a Tab as it is loading then Wayfarer "meditates" - are you aware of that?
jacadcaps wrote:No and unless you can provide me with logs, there's little I can do about this. I haven't been able to reproduce this myself. Same for your other crashes.
Logs to follow tonight - stand-by for more e-mail attachments from me.
Quicklinks - jacadcaps wrote:There's no limit but it won't create new lines. Maybe later.
OK, that's great that you'll consider improving the features.
NewSense wrote: With OWB you could use the right-mouse button context-menu to trigger options to open in another Tab
jacadcaps wrote: Wasn't even aware of that. You can click a quicklink button with MMB to open the link in new tab.
Well you learn something new everyday, I know I do -> , and thanks for letting me know the MMB is intended to open a QuickLink in a New Tab - that works really well.
Quote: NewSense wrote: Also, here's
another anomaly - if you
left mouse-click on the Bookmarks menu you can
see both the Sub-Menus, that's including their Sub-Menus . . . BUT . . . if you use the
right-mouse button context menu to access the
Bookmarks then you only get to see the
first level of Sub-Menus, weird or what!?
jacadcaps wrote: That I believe depends on your MUI settings, namely Menus > Appearance.
That can't be correct because my MUI > Menus > Appearance options are basically the same for both browsers - I'll send you a screengrab via email for you look over and confirm.
Quote: NewSense wrote: Also, a strange webpage layout that doesn't occur on OWB or on Firefox of Microsft Edge or Ten Four Fox AFAIK, in that when you load up
PageStream DTP webpage...
jacadcaps wrote: That page looks broken on Vivaldi/Chrome (and in Safari, just a different layout issue) so I'm not going to bother investigating. That's something for Deron to fix.
I'll agree with that, as Deron has been told about the header and some other features that aren't correct, don't work properly, and he's failed to fix them for years now, which gives a really bad impression of a developer - I am sorry to say, and that certainly does not apply to you. (@
jacadcaps)
I notice that it is also possible to transfer the Quick Links from one version of Wayfarer to the next by copying the bookmarks.json file to the Settings folder in the later version, so that saves some effort, as it can be fiddly to set it all up in the 1st place.
[ Edited by NewSense 20.10.2020 - 00:49 ]MacMini 1.5GHz,64MB VRAM, PowerBooks A1138/9 (Model 5,8/9),PowerMac G5 2.3GHz(DP), iMac A1145 2.1GHz 20", all with MorphOS v3.18+,Airport,Bluetooth,A1016 Keyboard,T-RB22 Mouse,DVD-RW-DL,MiniMax,Firewire/USB2 & MacOSX 10.4/5
