    Posts: 1390 from 2010/1/6
    There was a server-issue by my provider: they delivered a wrong system-time for about 6 hours in some Austrian regions! But you'll recognize this only - under MOS (not Win or Linux) - , if your PC takes the time from server and not from internal RTC (with empty backup-battery .... :-( ).
  • »03.01.25 - 17:35
    ernsteiswuerfel
    Posts: 571 from 2015/6/17
    Anyone able to login to https://www.a1k.org/forum/index.php with Wayfarer 9.0?
    On my G5, klicking on the Anmelden-Button loads for a short while but the Login-Requester does not appear. This used to work with Wayfarer 8.x.
    So far I deleted Wayfarer cache and used the other different spoofing settings but that didn't make a change.
  • »06.01.25 - 09:03
    Can confirm: Anmelden does not work!
    "Registrieren" takes a while but then appears the Registrieren-window.
  • »06.01.25 - 10:04
    SkulleateR
    Posts: 77 from 2023/9/19
    Can confirm too ;-)
    Quick workaround for now, right click + open in new TAB :-)
  • »06.01.25 - 12:28
    Seems also to work, if Adbocker is deactivated. In that case you can do a new answer or a quotation - editing of own answers is not possible......
  • »06.01.25 - 15:57
    Posts: 3336 from 2003/3/5
    Wayfarer 9.1 is now out!
    - Rebased to WebKitGTK 2.46.6
    - Fixed reported crashes
    - Updated libcURL, libtasn, libgpg-error, libgcrypt, liblcms2, libnettle, libpng16, libwebp, libxslt, libsqlite
  • »10.02.25 - 00:30
    Papiosaur
    Posts: 2607 from 2003/4/10
    Nice news! Thanks a lot jacadcaps!
  • »10.02.25 - 07:13
    tolkien
    Posts: 582 from 2013/5/29
    Jacadcaps for president!
  • »10.02.25 - 09:17
    Posts: 919 from 2004/1/24
    w00t :-D
  • »10.02.25 - 13:17
    Trekman
    Posts: 50 from 2020/11/10
    grrreeaaatttttttttttttt.....:-) :-) :-)
  • »10.02.25 - 17:31
  • pOS
    pOS
    Posts: 220 from 2003/11/14
    As there is no entry in the menu, can somone tell me, which is the key shortcut to switch to fullscreen mode ? The common F11 does not work.
  • »13.02.25 - 23:05
    NewSense
    Posts: 1618 from 2012/11/9
    @ pOS - Have you created a MUI screen to use Wayfarer on? That way you will be able to use it on a full size screen, or you can just use the window sizing gadget or Ctrl+edge of GUI window border left mouse-press option to resize it on the screen it is on to make it sized to the maximum it can be on the screen it is on.
    Is there a "common F11" keypress on MorphOS that I don't know about? :-? 8-)
    The only "Function" key assignment I know of in MorphOS is for the iMac and that is F1 + F2 to adjust the brightness. AFAIK there are none assigned other than that? :-?
  • »14.02.25 - 04:53
    ernsteiswuerfel
    Upgrade to MorphOS 3.19 and Wayfarer 9.1 worked flawlessly on my G5, thanks!
    The workaround for the "Anmelden"-Button on https://www.a1k.org/forum/index.php is still needed.
  • »16.02.25 - 15:04
    The "Login-button" at a1k.org does'nt work anyway. As "workaround" you can do following:
    Put a older version of Wayfarer (eg. V8.x) to the same directory as Wayfarer V9.1.
    Run it, do the login and choose permanent login.. After success shut down Wayfarer and start V9.1 and it will work.
    Older version can be deleted.
  • »16.02.25 - 18:06
    analogkid
    Posts: 722 from 2004/11/3
    The same thing occurs here, too.
  • »17.02.25 - 01:06
    Do any of you have contact to the website maintainers? Debugging such things is very hard without being able to modify the site.
  • »17.02.25 - 16:02
    The a1k login error is now fixed. 9.2 should be out in a couple of days.
  • »18.02.25 - 15:54
    Very fine!
  • »18.02.25 - 17:53
    ernsteiswuerfel
    Thanks Jaca!
  • »18.02.25 - 18:05
  • pOS
    pOS
    Hello,
    you suggest to simulate a fullscreen like behaviour.
    What I meant was a real fullscreen mode, that only shows the content from inside the web site with no gui elements at all.
    Wayfarer has such a mode. You can experience that when you watch a Youtube Video and press the fullscreen button there.
    Wayfarer opens a new Custom Screen and uses the same resolution as your Ambient/Workbech/Desktop screen has.
    You can switch back to Ambient screen with <lamiga><m> as usual.
    There you see that the tab of the website has a text like "this content is shown in fullscreen now. Doubleclick in this tab or ESC on the fullscreen to end fullscreen mode".
    Actually you can have several web sites shown in fullscreen, each on it's own screen and others being not in fullscrenn mode , all at the same time.
    Problem is, that I do not know the keyboard shortcut to switch to fullscreen. And there is no menu item either.
    Common key in web browsers to switch the mode is F11. That works in Edge, Firefox, Chrome, OWB/Odyssey.
    To show hwo fullscreen behaves like in Wayfarer, save this code to fullscreen.html and open it in Wayfarer:
    <!DOCTYPE html>
    <head>
    <title>
    Fullscreen Demo
    </title>
    </head>
    <script>
    function toggleFullScreen() {
    if (!document.fullscreenElement) {
    if (document.documentElement.requestFullscreen) {
    document.documentElement.requestFullscreen();
    } else {
    if (document.exitFullscreen) {
    document.exitFullscreen();
    </script>
    <body>
    <button onclick="toggleFullScreen()">Toggle Fullsreen</button>
    </body>
    </html>
    [ Edited by pOS 18.02.2025 - 21:34 ]
  • »18.02.25 - 19:32
    I'm not sure that fullscreen mode is what you want.
    I would assume what you want is Wayfarer showing its normal window on a screen with no window frame but tabs and navigation bar still visible, like the browsers you've mentioned do.
    Such mode does not currently exist.
  • »18.02.25 - 20:14
    Wayfarer 9.2 is now out and fixes endianness problems introduced in the WebKitGTK 2.46 branch.
    As always, please update using the auto-updater.
  • »20.02.25 - 13:39
    analogkid
    Thanks jaca!
  • »20.02.25 - 14:19
  • IKE
    IKE
    Posts: 150 from 2009/11/7
    Thanks Jaca!
    IKE
  • »21.02.25 - 00:32
