    Posts: 2188 from 2003/2/24
    matt3 wrote:
    Cego wrote:
    i see, then i will have to save up for an X5000 as i dont trust those 20 year old G5s (already had 2 machines that died)
    I think for my Peg2 its best to use Wayfarer and OWB in tandem. Thanks for the fast reply
    I can promise you a PCIe Single Processor (Not the 2.5 quadcore) PowerMac will be the most reliable long term MorphOS solution we have. It will outlast an X5000, maybe not the Peg 2 (as long as you secured the fan on the G4 to stay secure).
    Yeah, Pegs have been surprisingly reliable I think, but generally speaking I'd trust more to big major players' hardware than these custom boards with small batches and limited testing.
    For example, X5000 has some generic looking issues like this:
    https://www.amigans.net/modules/newbb/viewtopic.php?post_id=148102
    https://www.amigans.net/modules/newbb/viewtopic.php?post_id=147195
  • »23.08.24 - 04:49
    Posts: 2520 from 2003/2/24
    There is no bulletproof HW.
    Have an X5000 (or SAM) fail under warranty -> lot of hassle and time to get it fixed
    Have any obscure HW (A1, Peg, SAM etc) fail after warranty -> you'll be spending big ($)$$$ IF your lucky
    Have an old Mac fail -> spend <200$ to find parts or a full replacement on ebay
    Now there is a simple and trivial solution for all this. One that had been kinda demonstrated 5 years ago, but......
  • »23.08.24 - 06:28
    matt3
    Posts: 762 from 2004/2/10
    @Kronos
    Sure, maybe not bullet proof but darn close!
    All the PowerMac users I talk to that own a business and used the platform, all used the PCIe single processor system. The dual 2.5's had a high failure rate and the PCIX stuff did fail more as well. The single processor PCIe stuff is the best from that era, that we luck out to use with MorphOS. As a bonus it is the fastest...
    The heatsink alone is a work of art :).
    If new hardware were to show up one day, I wouldn't be upset :)
    [ Edited by matt3 23.08.2024 - 09:57 ]
  • »23.08.24 - 11:56
    matt3 wrote:
    @Kronos
    When the HW was like 5-10 years old, but we are pushing 20 years even on the newest stuff.
    So far I haven't had a full age related failure with a PPC Mac and I do have plenty to go around for a while, but there is no question that this will become an issue and a big one with non standard parts, like PSUs or odd sized fans.
    There is also the issue that we have reached the performance ceiling for PPC HW and short of drastic changes usability on the net will slide backwards no matter how much work gets poured into Wayfarer.
  • »23.08.24 - 12:14
    matt3
    @Kronos wrote:
    Performance for everything I use on a daily basis, is just overkill really.
    You called it with Wayfarer and hardware, I use Wayfarer daily but big sites can be frustrating...
    At least with the Powermac stuff there are plenty of spares in the market if the power supply were to fail. Even old Amiga classic stuff is available enough to keep them going, lol.
    What ever happened to the drivers from bigfoot? I forgot about that, did they ever get done?
  • »23.08.24 - 12:32
    Cego
    Posts: 738 from 2006/5/27
    The issues with the G5 don't stop at the CPU. When the power supply dies, you have no chance of repairing it, let alone the amount of work to deconstruct the machine. The G5's are a waste of time, money (power consumption) and health (lifting that piece of metal is not the best execercise for our back).
    I haven't seen any dead Pegasos mainboards. Some people fried their CPU cards due to overclocking and wrong cooling. But if you maintain the machine on a regular basis (which is pretty easy), there should be no issues. Too bad there are no custom CPU modules with 7447A CPUs at higher clockrates available. Even with the limited RAM speed, a higher clocked CPU would increase the speed of applications like Wayfarer a lot.
  • »23.08.24 - 12:56
    matt3
    I would just buy another one and move the cpu and drive over and call it a day... Agreed they are the 3000T's of powermacs with all the back joy in that (just moved my 3000 tower 2 hours ago, lol). I have never tested a Peg II against the PCIe PowerMac. I have to believe the speed differential is pretty great, so for me it is totally worth it to own one. To date I have never seen a single processor PCIe PM fail, so I suspect they will be pretty reliable going forward.
    Peg II's were a huge issue early on with the cpu coolers. I lost 2 cpus because of that defect. The last cpu card I received from BBRV had a corrected heatsink mount and it worked perfectly. Minus the CPU, the Peg II's were simply awesome...
    [ Edited by matt3 23.08.2024 - 13:05 ]
  • »23.08.24 - 14:04
    Posts: 3256 from 2003/3/5
    NewSense wrote
    I was able to download the Black & Decker manual just fine from manualls.co.uk, even via a UK VPN...
    manuals.com doesn't seem to work at the moment. manualslib.com works just fine, including downloads.
    Haven't seen any 'power user' errors when using ebay.co.uk, either (also via a UK VPN).
    I can only conclude that your problem is entirely local. Either your ISP got marked as shady and you get more captchas and other checks than I or other users do, or your clicking patterns tend to trigger additional protections on various websites - that'd be a case if you did too many clicks at once, etc. It's likely worth waiting until a website fully loads before you start doing anything on it. In case of manualls.co.uk it takes about 10s from clicking 'Download manual' to getting the download popup. The website does a lot behind your back when you do click on it and it will fail miserably if you click it before it has finished loading.
    I'd recommend:
    - try out a different ISP, perhaps by tethering on your phone
    - patience, wait for websites to finish loading
    - reach out to Ebay support as they are the only ones who can help you fix your "power user" problems.
  • »23.08.24 - 14:05
    NewSense
    Posts: 1562 from 2012/11/9
    jacadcaps wrote: I was able to download the Black & Decker manual just fine from manualls.co.uk, even via a UK VPN...
    I seem to have triggered some in-house download limit on this site. How that has happened I have no idea. :-?
    However, I have sent the website a message asking for them to explain why there is a limit on my profile, as I cannot think of a reason why this would have been triggered in the first place, though their website message says that I got "over excited" and caused this situation - how that happens by pressing keys on a keyboard and moving and clicking a mouse, well a trackball in my case, in a normal way I don't know! :-?
    jacadcaps wrote: manuals.com doesn't seem to work at the moment.
    I think I misquoted the website name, but used the correct link in the text, that being ... https www manualslib com
    jacadcaps wrote: manualslib.com works just fine, including downloads.
    but not for me
    jacadcaps wrote: Haven't seen any 'power user' errors when using ebay.co.uk, either (also via a UK VPN).
    I've since retried using Wayfarer v8.11 and this time with a basic download and no personalisation, such as quicklinks, cookies, etc. then Wayfarer v8.11 loaded up correctly on the ebay UK website and allowed me to login . . . seems very strange, but I am glad it's working OK now, and why it made that "bot" and "Power User" appearance I just don't understand!
    jacadcaps wrote: I can only conclude that your problem is entirely local. Either your ISP got marked as shady and you get more captchas and other checks than I or other users do, or your clicking patterns tend to trigger additional protections on various websites - that'd be a case if you did too many clicks at once, etc. It's likely worth waiting until a website fully loads before you start doing anything on it.
    I'm aware of the necessity to allow webpages to fully load up, but sometimes it is taking an extremely long time for them to do so, but I usually watch the loading gauge to ensure the page is fully loaded before I start to do anything that might upset the situation, but why manualslib.com does nothing when I access it, other than get me frustrated I do not know, but I am avoiding it for now, as their website doesn't trigger the "Send message" button when I click on it, so it won't even allow me to send a Contact Us message to find out why this situation exists for me currently.
    jacadcaps wrote: In case of manualls.co.uk it takes about 10s from clicking 'Download manual' to getting the download popup. The website does a lot behind your back when you do click on it and it will fail miserably if you click it before it has finished loading.
    Noted, and I was aware of that basically.
    jacadcaps wrote: I'd recommend:
    Thanks for your long and lengthy explanation, it is much appreciated. However, I don't think that is necessary as I can once again access ebay - even using v8.11, and I can access all the other websites, but I just cannot download manuals from 2 websites - due to some issue they have that I may have stumbled over/into . . . for whatever obscure reason . . . who knows!!
    I will bring the situation to the attention of my ISP, who I have good communications with, and see if there is something they can determine that has happened on my profile to besmirch it in the online realm! ;-)
  • »24.08.24 - 04:06
    Cego
    The G5s are way faster than the Peg2, but honestly i cant think of much software that would need that much power. The only two programs that could use more speed on my Peg2/G4 are Wayfarer and Dosbox (for some 3D games like Screamer). OWB-JIT is pretty fast though and has nice and fast scrolling too. Iris runs nicely just like all the other MorphOS Apps. For a retro NG Amiga experience this is all i need.
    My Pegasos 2 comes in a MicroATX case with low-profile PCI Slots, which takes up very little space. For me the benefits of this kind of setup outweights the power advantage of the G5.
    Getting a new G5 isn't easy as well. You really can't ship it, so you have to go and pick it up somewhere.
    1
  • »24.08.24 - 06:48
    Cool_amigaN
    Posts: 776 from 2011/11/30
    Nice setup you got there Cego. Is the 1200 connected to the same monitor with the Peg? If yes, what's the monitor? Nice Commodore speakers too!
  • »24.08.24 - 08:10
    Cego
    Thank you :)
    Monitor is a Fujitsu B22W-6 LED
    Yes they are all connected to this monitor. It has 1xVGA, 1xDVI and 1xDP input.
    I can switch between Amiga RTG, Amiga Indivision MK3 and Pegasos2.
    The A1200 is also connected to the 1081
  • »24.08.24 - 09:00
    matt3
    @Cego
    That is a real nice setup!
    I have never had any issues finding a PCIe PowerMac easily and getting it shipped to me. Perhaps, because I'm in the US...
    I also watch movies and the extra speed help. Wayfarer performs pretty well on this box as well.
    Since I use this system for productivity every day, I want that to go as fast as possible.
    I use 2 monitors 1 1080p and the other 4k, and I doubt the radeon 9800 could even handle it. I use PolyOrga, Iris, Wayfarer, vpdf, Pagestream, and Turbocalc (one of my 2 68k items I still need, let's hope Microexcel comes to the rescue) all at the same time on different screens. I really loved my Peg II and wish I kept it sometimes, but these PowerMacs PCIe systems are very well made and perform well, so until a better hardware solution comes out I'm gonna stick with them...
    I will post a picture of my setup after I clean my office... :)
  • »24.08.24 - 09:32
    Posts: 12460 from 2003/5/22
    You can, and I have done it. You just need to take some extra packaging care to avoid bending of the housing.
  • »24.08.24 - 22:21
    Work on Wayfarer 9 has now started since WebKitGTK 2.46.0 is out...
    [ Edited by jacadcaps 21.09.2024 - 02:19 ]
  • »20.09.24 - 12:50
    matt3
    jacadcaps wrote:
    Work of Wayfarer 9 has now started since WebKitGTK 2.46.0 is out...
    I barely got to use 8.11! You better slow down. :)
  • »20.09.24 - 13:12
    First post from Wayfarer 9 :) There's some problems left, but it generally works!
  • »29.09.24 - 20:52
    tolkien
    Posts: 556 from 2013/5/29
    More fantastic news in MorphOS land!
  • »01.10.24 - 14:20
    Posts: 915 from 2004/1/24
    w00t :-D
  • »01.10.24 - 18:08
    Primax
    Posts: 200 from 2021/7/2
    Should Twitch videos basically work...?
    Don't get it running with Wayfarer 8.11. Tried all the different spoof options and had all video options enabled.
    Example: https://www.twitch.tv/videos/2266760600
    By the way: I can neither cancel nor agree to the Cookies...
    [ Editiert durch Primax 05.10.2024 - 20:52 ]
  • »05.10.24 - 05:11
    Won't work. The video itself likely would, but that site is so full of JavaScript and visual bloat, that those bits take way too much CPU.
    [ Edited by jacadcaps 06.10.2024 - 03:17 ]
  • »05.10.24 - 23:17
