Posts: 1596 from 2012/11/9
Additional to my above comment . . .
Very recently, last few day(s),
eBay (UK) now have a red banner headline that basically reads as "
if you want to continue to buy or sell on ebay then you need to upgrade your browser", which as I am running v8.6 of Wayfarer there is no option to upgrade it for MorphOS, and with being unable to edit the User Agent field (even though I am supposed to be able to do so) then I cannot imitate a browser that is supported fully by eBay it seems.
Also, my system (of recent), and
only with regard to Wayfarer, as even OWB (Odyssey) does not exhibit this weird behaviour it seems, as text highlighting with Ambient and other programs seems to work as it always has done, now fails to allow left mouse buttton dragging highlighting of text -
only when using Wayfarer!
In that if I position my text cursor prior to or after where I want to drag the cursor position to the left or the right, or even up or down, but then the text does not get highlighted, which is really weird, and the first time this has ever happened with MorphOS - well specifically Wayfarer. Also the Copy option does not get shown in the drop-down menu, UNLESS I have highlighted the text using the keyboard option, which seems to be the only way I can highlight text now other than to "Select All"!
There is still limited text highlighting, but where you have usually been able to select text virtually anywhere on a page by dragging your mouse over the text with the left mouse button held down, that function predominantly no longer works any more!
So, do I need to change some setting or has some part of MorphOS got corrupted in some way?
However, I can highlight text using the keyboard - is there a way I can correct this or is this some sort of corruption in Ambient or MUI that needs to be addressed?
That said, it
only seems to relate to text mouse-drag-cursor highlighting when using Wayfarer!
Maybe this text editing issue is also affecting the situation that I cannot amend the supposed to be editable field for customising any User Agent option?
Also, with v8.6 of Wayfarer the screen redraw/refresh seems to be at its worst implementation yet, as often a screen, tab or window presumably gets updated but the refresh is either not shown fully or just does not happen, or only partially happens, so you end up having to click another page or tab and then return to the tab in question to see that it has then been refreshed and the current view has actually now been displayed, which can be quite disconcerting / alarming!
MacMini 1.5GHz,64MB VRAM, PowerBooks A1138/9 (Model 5,8/9),PowerMac G5 2.3GHz(DP), iMac A1145 2.1GHz 20", all with MorphOS v3.19+,Airport,Bluetooth,A1016 Keyboard,T-RB22 Mouse,DVD-RW-DL,MiniMax,Firewire/USB2 & MacOSX 10.4/5
