  • man
    man
    Posts: 136 from 2019/11/11
    thanks jacadcaps
    else some sites like adidas works now
  • »09.04.24 - 11:25
    Posts: 3277 from 2003/3/5
    Writing this from Wayfarer 8.0. Basic port is now done. It remains to be seen how much more I'll have to spend fixing and debugging - media player had so many changes for example, that it will take me a while to restore basic functionality there. All in all, it looks like 8.0 release is now 2 weeks away.
  • »28.04.24 - 22:53
    NewSense
    Posts: 1576 from 2012/11/9
    @ jacadcaps - thanks for the update, and for all your (& Piru's) effort that's required to keep Wayfarer relevant, and as up-to-date as possible, for us all to enjoy using it. :-D
    MacMini 1.5GHz,64MB VRAM, PowerBooks A1138/9 (Model 5,8/9),PowerMac G5 2.3GHz(DP), iMac A1145 2.1GHz 20", all with MorphOS v3.19+,Airport,Bluetooth,A1016 Keyboard,T-RB22 Mouse,DVD-RW-DL,MiniMax,Firewire/USB2 & MacOSX 10.4/5
  • »29.04.24 - 01:20
    Wayfarer 8.0 is now available for download.
    It's getting increasingly hard to update WebKit. This version either deprecated or broke a lot of the compile time options I've been using to customize the build. This means I had to put more work into this upgrade than with version 5, 6 or 7.
    Please consider donating if you appreciate my work.
    [ Edited by jacadcaps 04.05.2024 - 03:34 ]
  • »03.05.24 - 22:57
    Posts: 1370 from 2010/1/6
    Tried to donate with Wayfarer 8.0 -> no PayPal login possible! Cannot write anything on login-page.
    Had to switch back to Wayfarer 7.x to log in....
    On videos on site https://orf.at/ sound does'nt work any more.
    Problem, I wrote in #1516 seems now solved - does what it should again.
    [ Editiert durch Amigaharry2 04.05.2024 - 11:18 ]
  • »04.05.24 - 05:23
    Posts: 2208 from 2003/2/24
    You can write on the login prompt, but it just doesn't get updated automatically. Resize the Wayfarer window to get it updated to the current input.
  • »04.05.24 - 08:53
    You must be getting a different login page in Europe than I'm getting in Canada, cause it's working just fine here.
    It doesn't work with Wayfarer 7.x either, so something must have changed on their end.
  • »04.05.24 - 14:57
    Papiosaur wrote:
    Bizarre, some crashes (send) at first launches... any idea? Now work fine... Maybe a memory problem...
    I'll take a look at the reports you've sent in the next couple of days...
  • »04.05.24 - 14:58
    Had a look at their HLS stream and they are now using a separate playlist(s) for their audio data. As in: it's no longer being encoded in the same chunks as video. I'll think about this, but it's going to be a major refactor to support, so no promises.
  • »04.05.24 - 15:13
    @jpv: Thank you! That does the trick.....
    @jacad: Interessting, i'm sure it worked (Video) a week ago, but it's possible they have changed - they allways change things from time to time.. But over all: V8.0 works very well!
  • »04.05.24 - 16:09
    Wayfarer 8.1 now out to fix the reported crashes.
  • »04.05.24 - 23:56
    Oh! Wow!
  • »05.05.24 - 06:18
    Posts: 38 from 2023/3/27
    Just made a small donation to support your awesome work and keep you motivated.
  • »05.05.24 - 12:18
    Big thanks to all who donated!
    Version 8.2 is now out. I've rebased to the latest stable WebKitGTK 2.44.1 since it fixes some of the additional crashes people were seeing.
    This version also enables lazy image loading support which may improve performance on websites using the functionality.
  • »05.05.24 - 15:07
    Sometimes Wayfarer cannot be quit. Requester occours, but does nothing when clicking on "Beenden".
    Cannot say what circumstances this behaviour causes - comes randomly.
    Have to reboot machine.
  • »05.05.24 - 20:00
    DanicaTalos
    Posts: 452 from 2010/10/15
    @ jacadcaps many THX for your hard work. I have testet PayPal with Wayfarer and it works. I send you a little bit THX in Euro :)
    iBook G4 - 14" -1,42 GHz - 32MB VRAM - 1,5GB RAM - 60GB mSata - MorphOS 3.19
  • »06.05.24 - 11:29
    emeck
    Posts: 175 from 2014/7/15
    @jacadcaps
    Everytime I use search or click the reply button in a thread Wayfarer 8.2 crashes.
    I also tried downloading and running 8.2 in a new location but same behaviour.
    Mac Mini PowerMac 10,2. I have send both cases bug reports. Hope those shed some light.
    PowerBook 5.8 MorphOS 3.18
    Mac Mini MorphOS 3.18
  • »09.05.24 - 17:28
    @emeck
    Saw the reports. I'm looking into it.
  • »09.05.24 - 17:36
    NewSense
    @ jacadcaps - Though v8.2 of Wayfarer seems to be stable and working OK, it is unable to upload photos to the ebay servers for any problems with an item it seems. I used to be able to upload these images as PNG files, though JP(E)Gs were not accepted, but now neither file type is accepted, and generates a server error at ebay that rejects the upload. :-(
    The same image(s) are accepted via Windows systems. I don't know what is the cause, but probably the fact that we are using a basically unsupported mainstream web browser cannot be helping our situation, but if there is anything you can do to fix this issue then I'd appreciate it.
    I know Wayfarer is well supported by you and Piru, but Cloudflare and others out there just don't care about that! ;-)
  • »14.05.24 - 01:25
    @NewSense
    You can try disabling HTTP/2 support in Network settings and see it that fixes image uploads.
  • »14.05.24 - 11:54
    Wayfarer 8.3 is now out with fixes for reported crashes, enabled Beacon API support and updated linklibs.
  • »15.05.24 - 18:00
    Posts: 916 from 2004/1/24
    w00t!!!11
  • »15.05.24 - 19:29
