    Posts: 1325 from 2010/1/6
    Wow! That's quick. Thank you!!
  • »08.02.24 - 17:58
    Posts: 908 from 2004/1/24
    jacadcaps wrote:
    Wayfarer 7.3 is now up. WebKit updated to WebKitGTK 2.42.5 which released just 3 days ago.
    Muy impressive :-)
  • »08.02.24 - 18:22
    Now some pages with captcha/login are working again.....very fine!
  • »09.02.24 - 08:11
  • JKD
    JKD
    Posts: 456 from 2003/4/4
    Is anyone else experiencing jerky playback (compared to 7.2) on YouTube with the 7.3 release?
    EDIT: This is happening on my G5 but only on the second monitor. if I'rn on Ambient or a regular public screen on the same monitor then it plays smooth.
    [ Edited by JKD 09.02.2024 - 11:30 ]
  • »09.02.24 - 17:09
    Posts: 3210 from 2003/3/5
    @JKD
    Hard to say, but if it's a separate monitor, it could be an issue with vram fragmentation or lack thereof.
  • »10.02.24 - 00:58
  • man
    man
    Posts: 136 from 2019/11/11
    in snopium i see in morphos:morphos/data/SSL/
    openssl.cnf missed
    i take it from amissl
    i don t know if it use and the impact
    i ll see later when download
  • »10.02.24 - 06:27
    @man
    That file is not needed. Don’t randomly copy files from amissl.
  • »10.02.24 - 11:08
    Wayfarer 7.4 is now available from auto-update.
    This update introduces a reworked settings UI, possibility to fine-tune browser settings per 1st component of a URL path as well as fixes of reported crashes.
  • »28.02.24 - 12:04
    Papiosaur
    Posts: 2408 from 2003/4/10
    Thanks a lot Jacadcaps for this new update!
    I see the menu is slow on morphos-storage, it's a problem of the website code or not well supported by Wayfarer for now? I think i see others menu slow on others websites... Github maybe...
  • »28.02.24 - 16:05
    Schweet!!!!
  • »28.02.24 - 18:41
    Wayfarer 7.5 is now out!
    - Fixed HLS Live video playback (live Youtube streams on mobile frontend)
    - Fixed reported crashes
  • »01.03.24 - 14:47
    Schweeter!!!11
  • »01.03.24 - 15:17
    Posts: 236 from 2003/7/28
    Very nice! Thank you jaca!!
  • »06.03.24 - 18:31
  • man
    man
    something strange happens
    go to meta morphos
    then automatic go to youtube
    i use withcleaner3.05 but not working
    certainly if i install a new wayfarer that will work again perfectly
  • »09.03.24 - 07:57
    There is a new issue since Version 7.4:
    If I want to printout a single transaction-row of telebanking, automatic logout is done for reason: time-logout or different tabs are simultainiously open, etc. In Version 7.3 everything works as expected.
    But other printouts on same web-page (e.g. summary over all) works.
    But there is an difference between printing single transaction-row and summery-print-out:
    In first case it opens a new tab with data to print-out, showing a further printer-Icon for real print-out (goes then to Wayfarers printing-view with printer-options).
    Wayfarer 7.4 opens this page, but does a logout (without showing any data to print). Wayfarer 7.3 shows correct data and let me do an normal print-out via Wayfarers printing-view-page..
    In second case (printing summary) both versions of Wayfarer jumps directly to printing-view and print out correctly.
    What I can say: There was no change in code on tele-bankimg-portal (asked therefore). Tried it also with different spoofings - no luck.
    At moment I have to switch back to V7.3 to do tele-banking.
  • »10.03.24 - 14:40
    Wayfarer 7.6 is now out with more video playback improvements and fixes.
  • »12.03.24 - 17:20
    discreetfx
    Posts: 399 from 2003/7/26
    @jacadcaps
    Great Browser for MorphOS, thanx for all the hard work.
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »13.03.24 - 01:09
  • man
    man
    works perfectly
    i use amissl last version
    i use after amispeed
    a better connexion for me with imac g5 2.1 ghz wifi original apple
    for youtube seems to work better and no adblock now (there is certainly youtube problem now with adblock)
    to be confirmed then
    thanks
  • »16.03.24 - 13:06
    analogkid
    Posts: 688 from 2004/11/3
    Wayfarer doesn't use AmiSSL. It uses MorphOS' own OpenSSL library.
  • »16.03.24 - 15:01
  • man
    man
    not in wifi
  • »17.03.24 - 12:57
    For the 100th time: Wayfarer does NOT use AmiSSL. No matter if you're using WiFi or not.
  • »17.03.24 - 17:28
    Cego
    Posts: 738 from 2006/5/27
    I'm getting a certificate error on morphos-team.net, wayfarer.icu and morph.zone. Wayfarer version 7.6
    Anybody with the same issue?
    Edit: Found the problem. Mainboard battery is dead and system clock was off...
    [ Edited by Cego 20.03.2024 - 19:26 ]
  • »20.03.24 - 18:18
    Wayfarer 7.7 is now available from wayfarer.icu and auto-update.
    Changes in this version include:
    - fixed WebAnimations support
    - fixed several issues with the internal refresh loop
    - fixed taking screenshots of scrolled-down pages
    - file:// handling fixes
    - updated libxml2
  • »20.03.24 - 23:33
