    danwood
    Posts: 95 from 2009/10/5
    Another incredible update Jacadcaps, you're an amazing asset to the platform!
  • »23.09.22 - 19:50
    MoerBoer
    Posts: 240 from 2019/10/15
    Busy watching your latest MorphOS video on the latest Wayfarer :)
    Nice video!
  • »24.09.22 - 07:30
    Cego
    Posts: 738 from 2006/5/27
    Thanks jacadcaps! I have installed it on my Peg2 and it runs just fine :)
    Are there any plans to support PPC JIT compiler to speed things up for weaker machines?
  • »02.10.22 - 19:57
    Posts: 3337 from 2003/3/5
    Initial view of the WebInspector, coming with the 4.3 update TBA later.
    [ Edited by jacadcaps 21.10.2022 - 21:14 ]
  • »21.10.22 - 17:01
    vulture
    Posts: 198 from 2008/2/4
    oh, very nice!
  • »21.10.22 - 17:05
    waldiamiga
    Posts: 96 from 2007/7/25
    Wow! It looks really appealing.
    MorphOS.pl
    Alienware 15 R3|WinUAE 5.x/AmigaOS4.1x & Icaros Desktop 2.x & QEmu 9.x.x
  • »21.10.22 - 17:33
    @waldi
    This is the standard inspector that's part of WebKit - same as Safari uses.
  • »21.10.22 - 17:38
    NewSense
    Posts: 1618 from 2012/11/9
    @ jacadcaps - so Eruda would be gone and replaced with this much improved webkit inspector, very nice. 8-D
    It looks far more comprehensive and better suited to Wayfarer than Eruda ever was, but glad we have some kind of inspector as a stop-gap . . . until you release v4.3. ;-)
    The site Free Icons dot com when you try to download an icon it states you have to answer the security question (captcha) - but Wayfarer v4.2 doesn't seem to generate the captcha option, so you cannot download an icon - well it hasn't worked for me as yet. :-(
  • »22.10.22 - 05:59
    Wayfarer 4.3 is now available!
  • »27.10.22 - 18:27
    Posts: 1390 from 2010/1/6
    Wow!! Thank you! Going to test.....
  • »27.10.22 - 18:56
  • IKE
    IKE
    Posts: 150 from 2009/11/7
    Awesome! Thanks jacadcaps!
    IKE
  • »27.10.22 - 23:10
    NewSense
    Wayfarer v4.3 still doesn't fix the website Free Icons Dot Com when you try to download an icon it still generates a JavaScript requester stating that you have to answer the security question (captcha) - but Wayfarer v4.3 still doesn't seem to generate the captcha option, so you cannot download an icon - well it doesn't work for me. :-(
  • »28.10.22 - 06:32
    Templario
    Posts: 561 from 2012/4/28
    Firefox neither shows the PNG icons, perhaps this site is for Chrome.
  • »28.10.22 - 07:09
    Posts: 31 from 2022/8/17
    I don't see a captcha in Chrome as well (on Linux, haven't tried it in Windows) - smth is broken on that site, it seems.
  • »28.10.22 - 07:15
    cip060
    Posts: 153 from 2010/7/30
    Does Wayfarer support or will it be able to support web telegram?What's UP ?
    https://web.telegram.org/z/
    It could be very useful
    [ Edited by cip060 28.10.2022 - 12:57 ]
  • »28.10.22 - 08:37
    @NewSense
    That site doesn't work for me in Chrome so I ain't going to waste my time on this.
    @cip060
    I actually have a build where Telegram sort of works again, but there's several remaining problems left for me to fix. I've had to implement Service Workers which are a feature never added to WebKit1. Still unsure when I'll find the time to finish this.
  • »28.10.22 - 11:17
    NewSense
    NewSense wrote: Wayfarer v4.3 still doesn't fix the website Free Icons Dot Com ... to answer the security question (captcha) - but ... doesn't seem to generate the captcha option. :-(
    jacadcaps wrote: @NewSense - That site doesn't work for me in Chrome so I ain't going to waste my time on this.
    @ jacadcaps - fair enough, thanks anyway for checking it out. 8-D
  • »29.10.22 - 03:31
    Tomtom76
    Posts: 49 from 2021/6/26
    https://www.2ix2.com/ - works with Chrome user agent but sound spooky. Perfect for Haloween but is it possible to fix that somehow? Unless someone can direct me to live tv website which works with Wayfarer. Thanks :-)
    Powerbook G4 A1106 MorphOS 3.20 & MacOSX 10.4
  • »30.10.22 - 09:56
    @TomTom76
    There's something wrong with the audio re-sampler. I'll investigate.
  • »30.10.22 - 12:05
    Tomtom76
    Thanks Jaca. I look forward for results.
  • »30.10.22 - 14:20
    Is there any way to make progress-bar (when loading websites) more visible. This small grey bar on grey ground is nearly invisible. Don't find any possibilities (MUI) to change....
    Found also problems with human identification (captcha). Works on some sites forever without any result (e.g. shop-apotheke.at)
    [ Editiert durch Amigaharry2 10.11.2022 - 08:37 ]
  • »08.11.22 - 16:47
    kriz
    Posts: 314 from 2005/10/18
    Loving it, first time really using it now and it is one impressing piece of work !!!
  • »10.11.22 - 09:44
    Wetransfer does'nt work any longer - gives only a blank screen.
  • »16.11.22 - 10:05
    You've got to provide more details than that. Don't assume I know every site on the internet, please.
  • »16.11.22 - 13:04
    Posts: 1362 from 2004/2/8
    I've observed that if I play any media (be it mp3 or a video) before running Wayfarer it hangs while opening its screen. Maybe it's the same bug?
  • »16.11.22 - 13:12
