Posts: 1596 from 2012/11/9
jacadcaps - thanks for the latest update, I'm sure it was more work, which I'm really grateful to you for . . .
. . . but I still cannot access the ebay message images that only load up as thumbnails. I can see it is a JavaScript issue, as that is in the message field in the bottom of the GUI, but it never triggers the images to load up from where they are kept on ebay's servers, which should open into a larger black bordered window, overlaid on the message window - is this likely to get fixed?
The reason I get so frustrated by this issue is that I have to get out of mothballs my Windows system to view the images, which is very irritating, as I dislike Windows, as it is so sluggish to do almost everything by comparison.
MacMini 1.5GHz,64MB VRAM, PowerBooks A1138/9 (Model 5,8/9),PowerMac G5 2.3GHz(DP), iMac A1145 2.1GHz 20", all with MorphOS v3.19+,Airport,Bluetooth,A1016 Keyboard,T-RB22 Mouse,DVD-RW-DL,MiniMax,Firewire/USB2 & MacOSX 10.4/5
