Posts: 1392 from 2010/1/6
jacadcaps schrieb:
@Amigaharry2
That stuff was implemented a long, long time ago. Select My Computer in the Folders list. Then open the main menu and select Folders > Map Local Folder. Select a directory in the asl requester. Press Add Folder in the new popup window. Done. Now you can drag emails to that folder.
Btw, you can also use this functionality to read mail in folders of other mail applications.
[ Edited by jacadcaps 02.08.2024 - 16:11 ]
Oh! Didn't realise that - impressive...!
Mails are stored as numbers - is it possible to store such outdropped mails with their subject as filename?
The reason is, that I have plenty of mails, which have to be archived local on PC or NAS corresponding to their belongs - with "speaking" filenames is easier to find them.
