Iris - An upcoming E-Mail client blog
    Posts: 1385 from 2010/1/6
    Ahhh - Ok. I missunderstood! Now it works - Thank you!
  • »07.01.21 - 14:16
    Cool_amigaN
    Posts: 776 from 2011/11/30
    @Jaca,
    About the Wayfarer string, I mean, open Iris, select Check for Updates -> tada, surprise! :P
  • »07.01.21 - 20:19
    Posts: 3324 from 2003/3/5
    It's called re-using code. But yeah, fixed in the upcoming 0.104 (or so, 103 is currently in beta tests). I've added a way to map your old email backup folders from other applications right into Iris.
  • »23.01.21 - 20:40
    Iris 0.104 is now available for download from iris-morphos.com. The new version makes it possible to map your email archives and folders of other email applications right into Iris. This release also fixes several crashes reported via the built-in bug reporting system.
    Do note that the Arexx port has changed from IRIS.1 to IRIS and needs to be adjusted in OpenURL settings!
    [ Edited by jacadcaps 24.01.2021 - 18:58 ]
  • »24.01.21 - 16:58
    NewSense
    Posts: 1614 from 2012/11/9
    @ jacadcaps - you're THE . . . MAIL-man now, thanks for all your almost exhausting to watch workload and output, stand-by for a donation for all your efforts, BIG thanks ! 8-D
  • »24.01.21 - 21:04
  • MDW
    MDW
    Posts: 498 from 2003/7/25
    Updated to 0.104. No problems.
    Iris 0.100+ rulez! :)
  • »25.01.21 - 07:22
    Thank you, NewSense and MDW.
  • »25.01.21 - 12:07
  • K-L
    K-L
    Posts: 46 from 2020/11/17
    Hello,
    Thanks for this update !
    Unfortunately, I still get crashes at closing of Iris (as you can see when I can send you the bugreport, since sometimes the whole system freezes when I click on "send bugreport").
    I don't know what is the cause of these regulars crashes.
    PowerMac G5 2,7 Ghz / Radeon 9650 / MorphOS 3.15
    AmigaOne X1000 (unused ATM)
  • »27.01.21 - 16:56
    Got same problems closing IRIS after updating over old installation - busy-bar runs forever. Installed completly new from scratch and now it works.But takes a relative long time to close (busy-bar!).
    Btw:
    I also did a new installation and copied "Settings"-directory fom old installation there: works exactly one time! Next time same behavieour.
  • »27.01.21 - 17:46
    Yeah, I know you do. I've had a look at the crashes and so far all I can say is that something (not necessarily Iris) is trashing memory. It would help if you could try to start it a couple of times with nothing running except Ambient - I see you have OWB, Hollywood stuff, MagicBeacon and many many other things running at the time of the crash. That doesn't make it easier in pin-pointing the issue.
    Also, run memtest extensive to check your memory.
    [ Edited by jacadcaps 28.01.2021 - 00:12 ]
  • »27.01.21 - 20:52
  • K-L
    K-L
    No problem, I'll make extensive tests without third party softwares.
  • »28.01.21 - 05:34
    MoerBoer
    Posts: 239 from 2019/10/15
    Check that your screenbar plug-ins are all up to date. I had an issue a while back where a module would kill the system when trying to quit Wayfarer on it's own screen and this plugin was running.
  • »28.01.21 - 08:32
    Version 0.107 is now available. Please take a moment to review the updated privacy policy.
  • »31.01.21 - 11:51
  • K-L
    K-L
    A big thanks for all the work !
  • »01.02.21 - 05:27
    Thanks for new version. Have you changed closing-mechanism (did'nt read something about) because it's closing now fast in a few seconds...
    Also thanks for updated privacy policy.
  • »01.02.21 - 07:13
    Posts: 1354 from 2004/2/8
    The part where it says "granted via pressing the Seng Bugreport button" is a typo, probably?
  • »01.02.21 - 11:05
    Haha, thanks. I'll fix that.
  • »01.02.21 - 11:18
  • pOS
    pOS
    Posts: 220 from 2003/11/14
    Or jacadaps has some Bavarian ancestors ;')
    ("seng" btw means "to see")
  • »01.02.21 - 17:24
    Cool_amigaN
    I confirm the above :)
    In the past (i.e. v. 0.100) it took about 5 secs for IRIS to close, now it's around 50% less. The same also speed increase happens when loading the app.
  • »02.02.21 - 09:30
    Shutdown speed depends on two factors: how long it takes to write the index file for the folder you've had open when you've quit the application and whether WebKit reports it needs more time to clean up. The bigger the folder - the longer it takes to shutdown.
  • »02.02.21 - 11:11
    Beta 108 is now available for download. Includes a fix for slow/very slow shutdown times.
  • »08.02.21 - 16:55
    Wow - first test shut-down: that's now really quick!
  • »08.02.21 - 18:25
    Iris beta 111 is now out!
    beta111:
    - Implemented a glossary
    beta110:
    - Implemented advanced search
    - Minor UI improvements in the mail writer window
    - Added a button to view all attachments at once
    beta109:
    - Further refined email suggestions
    - Implemented a workaround for broken servers when new messages are found in folders that
    are already open
  • »15.02.21 - 01:37
    Iris beta 112 is out! This version adds MDN support (read confirmation requests).
  • »17.02.21 - 12:46
