Iris - An upcoming E-Mail client blog
    Posts: 3286 from 2003/3/5
    See if you can get a repro and check which task is causing the CPU usage with TaskManager. If you get this again, enable developer mode in TaskManager's tooltype, run TaskManager, find the offending Iris process and select Dump State from the context menu in TM. Send me the log - I should be able to pinpoint where it happens.
  • »10.02.19 - 15:51
    Irs beta 48 is now available
    Changes:
    - Updated the underlying vmime library to its current latest and greatest state from github
    - Iris (and vmime) are now built using GCC 8
    - Fixed an input parsing bug that cound in some cases lead to an infinite loop when preparing a message to be displayed
    - Fixed an issue with HTML views not rendering anymore after closing a message window
    - Fixed: The message loader thread used in Load Message didn't have enough stack, leading to a disastrous end when opening emails from file that had a more complex structure (attachments)
  • »15.02.19 - 18:18
    Re-download Iris for beta 49:
    - Minor speed optimizations when loading a folder index file from disk
    - Fixed html editor/viewer context menus
    - Fixed the iconify icon
    - Added a PayPal button
  • »17.02.19 - 06:32
    ernsteiswuerfel
    Posts: 571 from 2015/6/17
    Are there any ppc/ppc64 specific benefits or general benefits using GCC 8? I refrain from using it on Gentoo ppc64 as 8.2.0 does not pass it's own testsuite yet. 7.4.0 is my default here. Adelie Linux still uses 6.5.0 to build their distro.
  • »17.02.19 - 11:53
    nujack
    Posts: 8 from 2006/9/8
    The latest versions I can't use anymore. After setup of my E-Mail-Account(Arcor, which is now Vodafone) the program freezes and I can't use it. Any idea what the problem causes? Could it be the size of my Mailbox which is filled with messages? Is there a Limit?
    Setup seems okay but when program starts to access mailbox it freezes.
    Screenshot
    [ Edited by nujack 21.02.2019 - 18:23 ]
  • »21.02.19 - 16:20
    It'd be a lot of help if you could run LogTool and send me the log (it's in Applications).
  • »21.02.19 - 16:30
    A new beta of Iris is now available for download.
    Features:
    - Improvements in the email editor; added default font (can be changed in settings)
    - Connected servers will periodically poll for new messages
    - Rewritten connection handling to improve performance and fix connection issues over time
    This version also fixes:
    - Switching between several displayable email compontents only worked once per component due to a bug in tmp file lookup
    - Fixed an issue related to saving attachments from an email open in a separate window after the active folder has changed in the main window
    - Improved server disconnection handling
    - Fixed a crash in vmime related to IMAP folder access
    - Unread messages count could sometimes be negative due to an overflow
    - Fixed a long-standing reconnection problem where internal exception routing would skip over the actual reconnection routine
    - Fixed an OAuth2 issue which caused servers to reject authentication if they weren't used for a long time (days) so that the refresh token expired - this delegates login back to the web browser as required by OAuth2
    - Worked around an imap.wp.pl issue where the server returns messages in a random order instead of sorting them by uid
    - Fixed a Sent folder refresh issue after sending an email
    - Fixed a wrong UID count in folder issue causing server commands to fail after emptying a folder
  • »04.04.19 - 16:53
    Posts: 916 from 2004/1/24
    Features:
    Thank you :-)
  • »05.04.19 - 16:22
    zbysiuk
    Posts: 59 from 2006/8/4
    Another portion of fantastic stuff - thank you.
  • »06.04.19 - 14:33
    ernsteiswuerfel
    Impressive list of updates! Runs fine so far on my G4 & G5. And seems somehat faster synchronizing & loading stuff!
  • »14.04.19 - 14:41
    Thank you! I'd also like to thank to all who have donated to either Iris or Odyssey's cause. There'll be a new Iris update coming out in the next few days.
  • »15.04.19 - 06:15
  • IKE
    IKE
    Posts: 150 from 2009/11/7
    You’re welcome! Keep up the good work!
    IKE
  • »15.04.19 - 12:30
    Not exactly a new thing since Odyssey supports this too, but it was quite a bit of work to get it to work in Iris... There's also Save as PDF. Should be available to all of you around the end of the week.
    [ Edited by jacadcaps 16.04.2019 - 21:47 ]
  • »16.04.19 - 17:46
    Posts: 1353 from 2004/2/8
    Czy tam zamiast "b" miało być "p"? Bo korekta nie wyłapała... :)
  • »16.04.19 - 18:49
    Tom01
    Posts: 187 from 2009/9/20
    "Settings / System / OpenURL / Mailers / Write Mail" is not saved. What could be the Problem?
    When closing MorphOS-Settings and open it again, the Write Mail Setting is empty.
  • »22.04.19 - 14:14
    You can force saving from the menu.
  • »23.04.19 - 12:46
    It's taking a bit longer than I'd thought: set out to make spellchecker Unicode-aware...
  • »30.04.19 - 07:22
    ernsteiswuerfel
    That will still be faster than Scribus getting a spellchecker. ;-)
  • »01.05.19 - 17:29
    Iris beta 60 is now available at tunkki
    Features:
    - Attachments in email views got new icons and a 'download and view in external viewer' button for types that can't be displayed internally
    - Load Message will now load Outlook .msg files (excluding purely RTF emails)
    - Added a 'Save all Attachments' button
    - Added an 'OPEN' rexx cmd
    - Improved mime type handling - fixes file names of extensions/embedded images when they are attched as a name without extension and mime type
    - Added Save as PDF (only the email loaded into a html view can be saved)
    Bugfixes:
    - Fixed an OAuth2 issue with Outlook
    - Fixed a bug that caused downloaded attachments to remain in the Tmp directory (Iris also makes sure to purge any stale files in Tmp on init now)
    - Improved handling of embedded images
    - Fixed a crash when doing NOOP on a disconnected but open folder
    - Fixed saving/viewing attachments of offline messages
    Please note that while I did add spell checking, Iris needs an updated spellchecker.library which is part of upcoming 3.12.
    [ Edited by jacadcaps 18.05.2019 - 22:09 ]
  • »18.05.19 - 18:02
    Cool_amigaN
    Posts: 776 from 2011/11/30
    Checking Iris for the 1st after managing to find time and upgrade from 3.9 to 3.11. At setup of Gmail account, I provide permission to the application through owb but 1st error appears at Iris as: cannot store message (sending is configured correctly). At Irs accounts testing receiving I get an error: Authentication test: Failure! Error while connecting socket. I checked also sending mail and get an error at bottom left corner "unable to find account / store failed". Any ideas what I am doing wrong?
  • »19.05.19 - 07:21
    This is odd and I regularly test with at least 3 different GMail accounts. Could you please remove the account from Iris, close the app and then run it from shell with 'trace' parameter? Send me the debug log, thanks.
  • »19.05.19 - 09:01
    asrael22
    Posts: 445 from 2014/6/11
    Hi.
    I'm not sure if I have a bug here, Iris beta60.
    When I have a mail with attachments, and I click on the attachment to be downloaded, it'll download.
    When I then click on other mails the downloaded attachment will always show as attachment of a mail even though this attachment is not part of the mail.
    Manfred
  • »09.06.19 - 13:24
