Iris - An upcoming E-Mail client blog
    jacadcaps wrote:
    And for some fun facts:
    Iris is now over 42000 lines of (my own) code and has almost 300 Objective-C classes & protocols. This excludes all the work that went into porting libraries and modifying OWB.
    As I was reading through the previous couple pages of this thread, I began thinking to myself, wow, what a huge task jacadcaps has taken upon himself. Probably much more work than you had initially anticipated doing to create a new MorphOS email program.
    I just relocated to begin seeing different doctors, so cash is a bit tight right now, but I will definitely send you a donation for all your hard work on this project, as soon as I can. I hope other users will do the same, when they are able.
    Thanks again for all you contribute to us MorphOS users.
  • »17.10.18 - 19:59
    Tom01
    Posts: 187 from 2009/9/20
    @jacadcaps
    Yes, that must be a Problem with VNC Server.
    Can you check that?
  • »23.10.18 - 13:39
  • rms
    rms
    Posts: 606 from 2004/11/27
    I still get the following line in log:
    Iris(imaps://christoph.poelzl@gmail.com@imap.gmail.com:993/IrisFolderCacheSynchronizeJob): Authentication error.
    Is there anything wrong?
    Regards
    Christoph
  • »25.10.18 - 02:44
    Posts: 3332 from 2003/3/5
    Basically accessing each IMAP folder means a new connection - which means authenticating separately. No idea why this fails for you. Could be anything from a bug in the implementation in Iris from a Netstack issue...
    I’ll try to add some more verbose info in the next release...
    Are you using the OAuth authentication?
  • »28.10.18 - 06:06
    @Tom01
    Could you try with Enhanced display being off?
  • »28.10.18 - 06:07
  • rms
    rms
    Yes, AFAIR, this was configured automatically during setup of account, it says OAuth Provider = GMail and then Authentication = OAuth2
  • »29.10.18 - 03:15
    ernsteiswuerfel
    Posts: 571 from 2015/6/17
    Beta V41 is working very well. I got nothing to complain about. ;-)
  • »29.10.18 - 08:44
  • rms
    rms
    I had Iris running for 24 hours in iconified state and this morning, I get these lines in the log:
    Iris(imaps://christoph.poelzl@gmail.com@imap.gmail.com:993/IrisFolderCacheSynchronizeJob): ENOTCONN: not connected
    Iris(imaps://christoph.poelzl@gmail.com@imap.gmail.com:993/IrisFolderJobOpen): ENOTCONN: not connected
    Iris(imaps://christoph.poelzl@rmsvideo.ch@server1.weboffice.ch:993/IrisFolderJobOpen): Socket is not connected.
    Normal?
    Best regards
    Christoph
  • »10.11.18 - 03:38
    Posts: 845 from 2007/10/23
    @rms
    Try "telnet imap.gmail.com 993" to check a connection at all.
  • »12.11.18 - 18:38
    Looks like a disconnection. Nothing you should worry about.
  • »26.11.18 - 20:14
    Iris beta 44 is now available.
    Changes include:
    - Detects urls in non-HTML emails and converts them into links when displaying in html viewer
    - Minor UI cosmetics
    - Signatures in Account settings
    - A toolbar in the main window
    - Link support in the HTML editor
    - No longer adds
    when replying to emails when the HTML editor is disabled
    - Added a 'Marked' items sorting order to the email list
  • »26.11.18 - 20:22
  • rms
    rms
    Hi, ok, but then when this error happens:
    I can't read the emails anymore which are not local but on the server :-(
    I need to quit Iris and start again so that it works.
    Shouldn't be normal, no?
    Best regards
    Christoph
  • »27.11.18 - 08:33
  • rms
    rms
    Best regards
    Christoph
    Hi, I also noticed that the above seems to happens when I iconify Iris then I get this ENOTCONN: not connected but when I leave the window if Iris open, then I rather get this in the log:
    Iris(imaps://christoph.poelzl@rmsvideo.ch@server1.weboffice.ch:993/IrisFolderCacheSynchronizeJob): Socket is not connected.
    and also this:
    Iris(imaps://christoph.poelzl@rmsvideo.ch@server1.weboffice.ch:993/IrisFolderCacheSynchronizeJob): Operation timed out.
    Best regards
    Christoph
  • »27.11.18 - 10:50
    corn
    Posts: 6 from 2003/10/3
    Thank you very much for beta 44. Iris is a very good mail application and the new beta very nice. I really like the new button bar. Even though the buttons are self explaining I think tooltips could be nice there nevertheless.
    Regards
  • »02.12.18 - 16:43
    Tom01
    @ jacadcaps
    Ah, with enhanced Display enabled it is working with VNC Server.
    With enhanced Display disabled there are Problems.
  • »02.12.18 - 19:43
    ernsteiswuerfel
    Beta44 works very well! Got nothing to complain about and the button bar comes in very handy. ;-)
  • »11.12.18 - 19:23
    @Tom
    Unfortunately I have not enough spare time to try and debug VNCServer.
    @all
    Thanks for all the kind words and reports - both of things working and not working. My MorphOS time is currently restricted to a few hours a week, so it will likely be a few more weeks before the next build is released...
  • »13.12.18 - 06:51
    g01df1sh
    Posts: 36 from 2015/5/28
    jacadcaps wrote:
    @Tom
    @all
    Hi Just tried your new beta 44 Iris. I did have a little issue where it setup fine the first time then I closed it and opened it again and all the windows where empty. I managed to get it working again by deleting the iris folder and also delete the iris entries in envarc and copy the iris folder back again and re do the account. One thing I would like in a future update is for the option to go straight to the inbox. keep up the good work im really starting to like Morphos now after many years of my powerbook sitting under my desk collecting dust.
  • »14.12.18 - 21:27
    Tom01
    @jacadcaps
    O.K. at least I can use it now.
  • »15.12.18 - 13:19
    Please note that all Iris versions seem to suffer from a bug where Iris sends an empty email if you close an email reader view after the writer window was already opened. No eta for a fix just yet.
  • »16.12.18 - 09:39
    Tom01
    Can Iris already be used by OpenURL?
    What would be the Settings for OpenURL?
  • »21.12.18 - 19:04
    Yes, check the README.
  • »22.12.18 - 05:11
    Iris beta 45 is now available.
    - Fixed the bug where Iris would send an email without contents if editing in html mode and some other html view was opened while editing
    - Tweaked the toolbar to avoid inflating the size of the folders column
  • »29.12.18 - 18:18
    Posts: 919 from 2004/1/24
    Well done!
  • »29.12.18 - 20:01
    Posts: 2730 from 2003/2/24
    You rule! :-)
  • »29.12.18 - 20:36
