Home
Forums
Library
Links
Bounties
Login Block
Nickname
Password
Lost Password?
Don't have an account?
Register now!
Search
Advanced Search
Forum Index
User Forums
Applications
Polynet config file where?
redrumloa
# 1
Posts: 1424 from 2003/4/13
I'm trying to remove Transfer from my Polynet bar since it is hopelessly broken. I don't see any way to do this easily so assume I have to edit some config file? Where?
TIA.
22.09.12
14:57
Papiosaur
# 2
Posts: 2591 from 2003/4/10
hi redrumloa,
go on button want to delete, do a right click and select "delete this button" then go on the bar, right click and select "save all".
papio-software.com
Ko-fi
www.meta-morphos.org
www.morphos-storage.net
22.09.12
15:09
redrumloa
# 3
Yowsa! I tried that before posting and just got the menu as if I right clicked on blank desktop. Working now... Thanks...
22.09.12
15:20
