SDL Full screen corruption
    danwood
    Posts: 95 from 2009/10/5
    I've recently been trying a few full screen games that all have the same issue, the graphics on full screen are just totally trashed, this happens with Pushover SDL version, ScummVM and a MorphOS diskmag I tried, the result is as shown in this image;
    http://i.imgur.com/RvhAZ.jpg
    I see it is running on an SDL screen, if I right click on the depth gadget from Ambient I can see the small preview and the screen looks ok in there, switching to it = bad corruption, is this an SDL setting or something else I need to do? If I configure SDL to run on Ambient in a window they work fine, but I want to play them full screen.
    Running 2.7 on Mac Mini 1,5mhz G4 64mb vram and 1gig RAM.
    [ Edited by danwood 11.05.2012 - 21:24 ]
  • »12.05.12 - 00:06
    Posts: 1520 from 2003/2/24
    What powersdl.library version you are using?
  • »12.05.12 - 06:10
    danwood
    I'm using powersdl.library 14.0
  • »12.05.12 - 12:15
    danwood
    @Papiosaur They all appear to be there.
  • »12.05.12 - 12:16
    danwood
    Just giving this a bump back up as not found a solution.
  • »14.05.12 - 19:34
    danwood
    Just another bump as still not solved this, and quite keen to play some SDL games now.
    I tried the Gunch remove/reinstall PowerSDL, no change though, I've also updated to MorphOS 3.0 then 3.1 since and same issue.
    I do get an error though from ScummVM
    WARNING: SDL mixer output buffer size: 1102 differs from desired: 2048!
  • »18.09.12 - 17:16
