Missing MUI icon from Pack Ultimate tool bar
    WeiXing3D
    Posts: 327 from 2012/6/13
    For some unknown reason I lost the icon of the MUI in the Pack Ultimate Toolbar at the bottom of the screen; the one with the computer screen, hat and the rabit.
    The application is still there and it works, but it shows the words "MUI" in letters instead/ How can I restore the original icon?
    Thanks in advance for any help.
    [ Edited by WeiXing3D 26.08.2012 - 21:56 ]
  • »27.08.12 - 05:23
    Papiosaur
    Posts: 2227 from 2003/4/10
    Hi WeiXing3D,
    i must start powerbook and see where is this icon in the pack.
    Try to edit MUI button and select this path for the icon:
    sys:prefs/MUI.info
    [ Edité par Papiosaur 27.08.2012 - 15:44 ]
  • »27.08.12 - 14:44
    WeiXing3D
    Papiosaur,
    @ papiosaur
    I checked in System:Prefs and I didn't find the MUI.info file/icon. Where can I find it so that I can put it back where it belongs?
  • »27.08.12 - 16:11
    WeiXing3D
    OK. Thanks.
  • »27.08.12 - 16:29
    WeiXing3D
    Papiosaur,
    @papiosaur
    I got the file, but I don't have a System:Prefs/A+ drawer under my Prefs. So where do I copy the MUI.info Icon? I sent you a screenshot to your email address for your refernce, showing the content of the Prefs directory.
  • »27.08.12 - 17:23
    WeiXing3D
    @papiosaur - Just to confirm that this has been fixed. Many thanks for the file.
    All Idid was to copy the file in System:Prefs/
  • »27.08.12 - 23:37
