Best Program for MED, MOD, IT, etc. Playback?
    XDelusion
    Posts: 602 from 2010/10/27
    As the title states, what's the best program to play all forms of musick modules under MorphOS?
  • »23.07.12 - 23:16
    Krashan
    Posts: 1107 from 2003/6/11
    The best program for this is UADE. In fact it is a reduced form of Amiga emulator using native 68k replayers, so it replays those old modules very good. Exciter Player is just a GUI for UADE.
  • »24.07.12 - 06:19
    connor
    Posts: 650 from 2007/7/29
    AmiNetRadio is a quite capable player with a lot of functionality and plugins. you will like it. It gets just beaten by TuneNet which sadly does not work on MOS. But ANR has some stability problems. It crashes not that rarely so you better save your data more often when using ANR. Does anyone know if ANR is about getting an update in the near future? It would be fine to see an updates version.
  • »24.07.12 - 13:01
    Posts: 12530 from 2003/5/22
    I think an update is unlikely, even more so in the near future.
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=9&topic_id=7308&start=26
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=6388
  • »24.07.12 - 13:26
    Cool_amigaN
    Posts: 776 from 2011/11/30
    Dunno but ANR crashes for me. Deliplayer (with 2.34 patch) also locks up my system. OTOH exciter works really fine however it lacks basic visual cues (for example audio volume control, time of song / playlist) etc. I hope its author can update it someday in the future :)
    Speakig of music.. can somebody explain me btw how I can play mp3s with the screen bar player?
  • »24.07.12 - 15:14
    Krashan
    By doubleclicking the file?
  • »24.07.12 - 18:42
    Cool_amigaN
    Unfortunately not. I have messed up the internal command string and canot re assosiate correctly the MIME type of mp3. How do I revert it to the default?
  • »25.07.12 - 05:51
    peg4a
    Posts: 26 from 2003/4/15
    Hi !
    The right command in Ambient/Mimetypes is :
    internal use : PlaySound %sp MULTIMEDIA OPENCONTROL (double click)
     8-)
    Powermac G5
    2,3 giga mono processor. HDD : 750 Go sata ATI 9800 XT 256 mo.
    Morphos 3.4 ;)
  • »25.07.12 - 06:03
    Cool_amigaN
    Hey, thanks!
    Unfortunately though I can't hear any sound (the song appears to be playng on sbar but I can't hear anything). That's on the default configuartion of MOS3.1 + PU 3.1. All other players I have used run well (e.g songplayer). When selecting Options of Ambient_SoundPlayer I get the following: Failed to create prefernces class. Hope that helps to determine the problem.
    EDIT: I rebooted and works fine! Many thanks! Only problem the error message "Failed to create preferences class".
    [ Edited by Cool_amigaN 25.07.2012 - 10:44 ]
  • »25.07.12 - 06:42
    XDelusion
    I loaded up ExciterPlayer with UADE last night...
    Amazing! My tracks sound as dirty as ever, thank you!!! :)
  • »26.07.12 - 17:01
    Cool_amigaN
    Exciter is unable to playback Jim Powers in Mutant Planet. I am checking my list of MODs for the time being and I will report the ones that don't work.
  • »27.07.12 - 04:24
