Moderator
                Posts: 441 from 2003/2/25
				Hi
Yes, I can play DVD on my Pegasos smoothly, and have done that since the beginning, on my Peg G3.
Im using AMP for this purpose.
A tip might be that playing DVD, and video over all, works best on a Radeon 7000, as you can use overlay with a such graphicscard, and what you yet can not do with a Radeon with higher number.
This means I for instance I can play in full resolution on its own screen as well as window on Ambient screen with exactly the same framerate if I prefer.
And please remember some DVD-drives doesnt work playing DVD with MPlayer in MorphOS, while they works perfectly with AMP or with MPlayer in Linux.
And some drives doesn't work with AMP in MorphOS, while they work with MPlayer in MorphOS.
The only solution to find out on this is to try out.
Will try the Peg II by now
Best wishes, Gunne
