Pack Ultimate -- updating pop up menu
    TheMagicM
    Posts: 1220 from 2003/6/17
    So Pack Ultimate installs some sort of floating menu... well, stuff in there does not execute.
    For example.. all of the UAE stuff..I click it..nothing runs. Where can I edit the menu to see where it is expecting this software to be installed at?
  • »10.10.11 - 22:50
    Papiosaur
    Posts: 2408 from 2003/4/10
    Hi TheMagicM,
    you must extract http://www.meta-morphos.org/download/emulators.lha archive where you want (eg Work:)
    after edit sys:prefs/env-archive/emuldest file and change path as Work:
    and take fun ;-)
  • »11.10.11 - 16:41
    TheMagicM
    ok...but in general... what file do I edit so I can add more options to the dropdown?
  • »12.10.11 - 00:15
    TheMagicM
    NICE! That did it! Thank you! I can edit menus, but E-UAE still does not launch. The "emuls:" assignment is correct, so is the path. Very odd.
    If you're the one who put Pack Ultimate together, you should pat yourself on the back. There are alot of utilities and various software that gets installed and saves me ALOT of time from having to find it, download it..
    [ Edited by TheMagicM 16.10.2011 - 07:41 ]
  • »16.10.11 - 10:28
    TheMagicM
    ok, I did a chmod +x on "rhLaunch" and it runs from the menu now. UAE config, UAE launcher and UAE GUI do not though. Still working on it..
    [ Edited by TheMagicM 16.10.2011 - 07:46 ]
  • »16.10.11 - 10:44
