Home
Forums
Library
Links
Bounties
Login Block
Nickname
Password
Lost Password?
Don't have an account?
Register now!
Search
Advanced Search
Forum Index
User Forums
Applications
Sound volume too low
TheMagicM
# 1
Posts: 1220 from 2003/6/17
Where can I adjust the sound volume under MorphOS latest? I have a G4 Mac Mini, and I do have it hooked up to external speakers but they are turned up almost all the way.
Thanks!
09.10.11
12:55
Papiosaur
# 2
Posts: 2620 from 2003/4/10
Hello TheMagicM,
normally, you can adjust volume in screen bar. You have a speaker on the right.
papio-software.com
www.meta-morphos.org
www.morphos-storage.net
09.10.11
13:08
TheMagicM
# 3
hmm..I guess it was the game I was playing.
With that said.. thank you. Fixing to register MorphOS right now!
09.10.11
16:14
