OWB - history
    mt12345
    Posts: 72 from 2011/4/4
    How to clear browsing history? (single adresses, one by one or whole history)
  • »20.07.11 - 06:40
    Posts: 12543 from 2003/5/22
    Settings -> OWB -> Privacy -> Save history
  • »20.07.11 - 08:20
    mt12345
    Yes, I can change it in prefs but it works 'from now on'. But how to clear history from past?
    I let my friend to use my computer for 2 hours and my browsing history is messed up with entries I don't wish to see.
  • »20.07.11 - 09:03
    You can move the "History Entries" slider to 10. And if you move "History Age in Days" to 1 those 10 entries will be gone by tomorrow. Or simply have history saving turned on, click 10 random links, then restart OWB and the mess from your friend should be gone.
  • »20.07.11 - 09:41
    mt12345
    Thanks, I was considering this, but this way I will loose the whole history...
    In firefox you just select the entry and press delete key. Simple and useful.
    OWB developpers! Will you add this feature in next version?
  • »20.07.11 - 09:53
    Yes, I meant to refer to the "whole history" part of your initial posting. I have no idea how to delete single entries in OWB.
  • »20.07.11 - 10:03
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    DeveloperS? There's only one, actually. :)
    Maybe I'll add that, i'll see.
    But please note that for this kind of usage pattern that involves a guest who shouldn't add his personal data, you could tell him to enable "private browsing" option. This way, no cookie, history, password and co will be recorded at all as long as the option is set (on a per-tab basis).
    [ Edited by Fab 20.07.2011 - 13:42 ]
  • »20.07.11 - 10:40
    mt12345
    The problem is, I noticed 'private browsing' AFTER my friend's session :-(
    I propose 2 more useful features:
    - keystroke to switch between tabs (CTRL+TAB)
    - RMB --> 'Search the Web' that opens in new tab
    Good job any way, I would like to see OWB working in x86 linux.
  • »20.07.11 - 11:20
    Jupp3
    Posts: 1193 from 2003/2/24
    How about Delete private data all / from last hour / last day / last week etc? (in other words, most recent data)
  • »20.07.11 - 12:19
    mt12345
    One more request:
    Middle click on tab header closes tab
    (so you don't have to click on [X] button)
    Of course there are many more things I would like to see in OWB
    like: mouse gestures, spell-checking etc, but the ones above are the most important.
    At least for me ;-)
  • »20.07.11 - 13:21
    > spell-checking
    Seems to come (scroll down to Fab's post):
    https://morph.zone/modules/news/article.php?item_id=1857&comment_id=5244&mode=thread
  • »20.07.11 - 13:38
    Henes
    Posts: 507 from 2003/6/14
    This one is already implemented for a long time.
  • »20.07.11 - 21:36
  • Fab
    Fab
    There's also ctrl + pgup/pgdown, and amiga+1, 2, n for specific tab indexes.
  • »20.07.11 - 21:55
    mt12345
    Indeed CTRL+TAB works. Not always though. If you click somewhere on web page it's deactivated.
    [A]+PgUp/PgDown always works.
    How about switching tabs using mouse wheel?
  • »21.07.11 - 09:40
