No Caps Lock with USB keyboard
    Motosampy
    Posts: 199 from 2004/8/14
    I just notised that caps lock is not working with my keyboards, tried 2 different with same result. I checked that in usb preferences key mapping is correct (never changed it from default). Any ideas ? Everything works fine under Linux and OS X
    PowerMac G4 MDD, MorphOS 2.7
  • »10.07.11 - 05:18
    Korni
    Posts: 473 from 2006/2/23
    Does capslock work with a clean MorphOS? Maybe it's disabled in mmkeyboard or some other program blocks it.
  • »10.07.11 - 18:26
    Posts: 2581 from 2003/2/24
    1st things 1st
    Go to settings->USB->Devices
    Select your keyboard and go to settings.
    In the tab "action" select "track incoming events"
    Now every keystroke should result in the listview jumping to the entry for that key.
    Does it react on caps-lock ?
    The key qualifier should be set to "toggle" and "caps lock"
    [ Edited by Kronos 10.07.2011 - 22:37 ]
  • »10.07.11 - 18:36
    Motosampy
    Thank you guys, it was MMKeyborad that was blocking it....
  • »10.07.11 - 18:42
    mt12345
    Posts: 72 from 2011/4/4
    I hate caps lock. I removed it from my keyboard
  • »19.07.11 - 05:44
    Marco
    Posts: 10 from 2011/4/9
    @ mt12345
    so do you now have a hole in your keyboard?
  • »19.07.11 - 12:44
    mt12345
    Actually I removed the rubber thingy under the key, then put the key back.
    So it is present, stuck deeper than other keys, but not functional.
    I did the same to menu key (the one between windows key and alt).
    NO MORE UPPER CASE :-D
  • »19.07.11 - 14:06
