File manager?
    mt12345
    Posts: 72 from 2011/4/4
    I need 2-pane file manager.
    I've installed Directory Opus 4 from Aminet,but when I launch it I got message:
    'Need version 1 of popmenu.library and version 1 of xadmaster.library'.
    Where do I get it and how to install? xadmaster seems to be shareware.
    Any alternative?
  • »13.07.11 - 17:20
    Jambalah
    Posts: 820 from 2008/3/30
    It seems xadmaster isn't shareware anymore:
    http://morphos.lukysoft.cz/vypis.php?hledat=xadmaster
    To install it, there is an install tool and even the included Amigaguide file should be useful (for a manual installation).
    You can give a look to FileMasterPPC too:
    http://www.meta-morphos.org/download.php?op=mydown&did=47
    [ Edited by Jambalah 13.07.2011 - 21:48 ]
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »13.07.11 - 17:38
    Posts: 12572 from 2003/5/22
    Yes, it was made open source 7.5 years ago.
    The XAD system is part of MorphOS since MorphOS 2.0:
    http://www.google.com/search?q=site:morphos-team.net+xadmaster
  • »13.07.11 - 17:55
    mt12345
    sorry, should be POPUPMENU, not POPMENU.
    Anyway installed xadmaster but still the same error
  • »13.07.11 - 17:57
    mt12345
    Installed FileMaster.
    'No bgui.library v41 or better found'
    I miss Debian's apt-get... :-(
  • »13.07.11 - 18:02
    mt12345
    Bgui installed. Filemaster working. Thanks!
  • »13.07.11 - 18:07
    > I got message: 'Need version 1 of popmenu.library and
    > version 1 of xadmaster.library'. Where do I get it and how
    XAD is already part of MorphOS, no need to install. For popupmenu.library:
    http://aminet.net/search?query=pmlib
    http://www.sintonen.fi/sw/pmlib-10.8.6-fix.lha
    http://www.sintonen.fi/sw/pmlib-10.8.6-fix.readme
  • »13.07.11 - 18:10
    > installed xadmaster
    So you have now two XAD installations. Nice ;-)
  • »13.07.11 - 18:12
    mt12345
    pmlib installed, dopus works.
    I didn't know I can (should?) install 68k amiga libraries on Morphos!
    Thanks again.
    By the way:
    Apart from (outdated) Pegasos Book, is there any MOS handbook/manual?
    I'm new here and I feel confused and lost.
    I would like to read some documentation, tips, tricks, kbd shortcuts etc.
  • »13.07.11 - 18:37
    I doubt that the XAD version or the BGUI version you installed are PPC native ;-) Anyway, I advice you to read Zylesea's brief introduction to MorphOS:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7710&forum=3
  • »13.07.11 - 18:53
    analogkid
    Posts: 722 from 2004/11/3
    I like Filer very much, it's a very good filemanager with few requirements, and quite configurable, too.
    http://aminet.net/package/util/dir/Filer4_07
  • »14.07.11 - 01:26
    Posts: 2220 from 2003/2/24
    Yes you can and sometimes need too :). But remember to install all stuff into SYS: and not into MOSSYS: (SYS:MorphOS/)!
    You can check if there is already native included version of the library (or any other component) in MOSSYS: and if not, install required one to SYS:. You can create corresponding directory in SYS: if it's missing. Whole MOSSYS: will be removed in the next OS update and installing into SYS: will keep your own modifications after the update.
    Only thing you should change in MOSSYS: is to rename old rexxsyslib.library when installing 68k one in the SYS:Libs.
    [ Edited by jPV 14.07.2011 - 20:16 ]
  • »14.07.11 - 02:58
    > native version of the library (or any other component) in MOSSYS:
    Please don't add to the common misconception that MOSSYS: vs. SYS: has anything to do with native vs. non-native.
  • »14.07.11 - 10:08
    mt12345
    Thanks for advices!
    I have just reinstalled the system and installed latest Ultimate Pack. Cool!
    There is no 2-pane file manager though.
    On first boot I got request to install rexxsyslib.library manually.
    Which package should I download? There is plenty of rexx-something packages on aminet
  • »14.07.11 - 10:44
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=6756&forum=3&start=29
  • »14.07.11 - 10:49
    C64Days
    Posts: 103 from 2006/2/27
    http://aminet.net/package/util/dir/DiskMaster
    no weird requirements (unless you upgrade to DM2 mailing list last betas asking for a release of Reaction only updated on OS4)
  • »14.07.11 - 17:02
    mt12345
    Neither 68k nor PPC version of DiskMaster works. (os4emu installed)
  • »14.07.11 - 17:51
    Posts: 2581 from 2003/2/24
    But did you also install ClassAct/ReAction ?
    Not that I would do that, not even if you offered me money (unless offcourse it's a lot of money).
  • »14.07.11 - 18:09
    mt12345
    I'll stay with DOPus. I will also test Filer and Filemaster. Thanks for replies.
  • »14.07.11 - 18:50
