New MorphOS User
    weGuru
    Posts: 4 from 2011/6/23
    I started with MorphOS 3 days ago, and ive got a few questions:
    1. After i installed the Ultimate pack ive got these eyes that follows my mouse. How do i remove them???
    2. How to i setup fileshareing with Windows, Linux and OSX?
    3. I downloaded and installed the Ultimate pack, i chose English but there are still some menues that are in french. How do i fix this?
    4. Im trying to run OS4 software and it tells me i need a OS4emu, where can i find one?
    And im on Powermac G4 Quicksilver 2002 by the way
    [ Edited by weGuru 24.06.2011 - 00:55 ]
  • »23.06.11 - 20:53
    Posts: 12562 from 2003/5/22
    MouseEyes is a screenbar plugin. You can enable/disable screenbar plugins by performing right-click on the screen cycle gadget (top right of Ambient screen).
    https://morph.zone/news/1523.html
  • »23.06.11 - 21:30
    Posts: 2220 from 2003/2/24
    2. You might try to use smbfs for samba mounting. It might not work with the latest Windows incarnations, but give a try. Probably comes with Ultimate Pack. FTP is always reliable and fast option too.
    3. Open pulldown menu Settings -> Ambient... -> Mime, find the problematic mime types and edit their command names to anything you want :)
  • »24.06.11 - 02:51
    Papiosaur
    Posts: 2613 from 2003/4/10
    Hi weGuru,
    Welcome to MorphOS communauty ;-)
    If you want you can registered to World map of MorphOS users (in my signature).
    About your question number 3 :
    Thanks for the info, i have correct the problem. New mimetypes in english will be available in finale version.
    Thanks a lot.
    [ Edité par Papiosaur 24.06.2011 - 12:52 ]
  • »24.06.11 - 03:46
    Posts: 655 from 2004/4/15
    Did i miss something? You started with MorphOS 3 a few days ago???
  • »24.06.11 - 08:52
    Posts: 2578 from 2003/2/24
    I'd say he started with MorphOS(2.7) 3 days ago  :-P
    [ Edited by Kronos 24.06.2011 - 13:04 ]
  • »24.06.11 - 09:04
    weGuru
    yeah it is MorphOS 2.7...and 3 days ago :)
    I got rid of the eyes, but samba dont start. Are there NFS support in MorphOS? If it is it could communicate with my UNIX systems and A1200 which would be nice.
  • »24.06.11 - 10:48
    Not built-in AFAIK. But there's software for m68k AmigaOS that might or might not run on MorphOS 2.7:
    NFS server:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=6020&forum=3&start=1
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=5636&forum=9
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=5160&forum=9&start=17
    NFS client from AmiTCP/Genesis package:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=6020&forum=3&start=3
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=4614&forum=32&start=4
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=2472&forum=9&start=5
  • »24.06.11 - 11:30
