Issues with the file copying from my Nokia phone
    Posts: 2094 from 2003/6/4
    I have issues with the file copying from my phone (Nokia C5, mounted as msd). I can access files from Ambient or Shell just fine, but I cannot copy them. I e. I can watch the photos (lousy pic quality, but gps tags) I took, but I cannot move them to hd. Ambient says "File #? is not complete. Dos Error: unkown (#45)", Shell says: "not copied.: Error 45".. But when I fire up Showgirls select pictures within Showgirl's browser and chose copy to from the context menu, the files just get copied.
    Of course all files on teh camera's sd card are rwed.
    Any idea what's wrong, somebody?
  • »02.05.11 - 09:32
    Posts: 846 from 2007/10/23
    ACK, I suppose it's a FATFileSystem bug  :-(
    Here comes my workaround:
    type Images/src.jpg to t:dst.jpg
    but you have to remove the last byte of dst.jpg!
  • »02.05.11 - 12:52
    Crumb
    Posts: 738 from 2003/2/24
    That very same bug happened to me with my Nokia Navigator. Decrease the maxtransfer of your phone in Trident to 64KB. Or copy the images with Directory Opus. AFAIK it's a bug related to Poseidon since it doesn't calculate correctly the max transfer of the device.
  • »03.05.11 - 15:23
    Crumb,
    Cool, that did the trick. Works with transfers of 128 KB though, too. With higher values the error appears again.
    But I don't understant why applications like Showgirls or Opus just do it.
    [ Editiert durch Zylesea 03.05.2011 - 23:40 ]
  • »03.05.11 - 19:38
