PowerSDL v15.0 release candinate
    Posts: 1521 from 2003/2/24
    Hello all!
    I have finally completed new version of powersdl.library. It is partially new port from the official SDL sources compiled using gcc4 so it may have loads of bugs I didnt notice yet (possibly in mutexes and file I/O). But it should fix some existing bugs (keyboard handling with French keymaps and some new HW :)) and probably runs faster.
    Download RC from here:
    http://www.amigasoftware.org/test/powersdl-21-10-2010.lha
    New release follows later this year.
  • »21.10.10 - 15:15
    kriz
    Posts: 314 from 2005/10/18
    Thanks! Good work, downloading now.
  • »21.10.10 - 15:16
    _DaNi_
    Posts: 154 from 2010/5/4
    thanks itix! great notice this!!!
  • »21.10.10 - 15:47
    SixK
    Posts: 72 from 2004/11/16
    @Itix,
    Great work, but this version seem's really too buggous to be usable to my point of view.
    Tested on MacMini 1,5Ghz + Morphos 2.6
    - Battle for Wesnoth seem's to work
    - Foobillard can't open screen
    - Mures can't open screen
    - Teeworlds crash or can't open screen
    - Fheroes2 have weird graphics
    - Meritous crash
    SixK
  • »21.10.10 - 17:21
    _DaNi_
    I test it now with the last OpenBOR v3 and crash with this new sdl library, i need to talk with you about SDL screens problems with SDL morphos
  • »21.10.10 - 17:43
    Thanks for bug reports, I finally fixed powersdl and uploaded new version 15.1:
    http://www.amigasoftware.org/test/powersdl_151.lha
    OpenGL and AHI support was broken and fixed in this version. There is still probably something I overlooked...
  • »03.12.10 - 22:01
    Daff
    Posts: 251 from 2003/4/5
    E-UAE_SDL doesn't work with v15 and v15.1. The emulator can't be launched.
    http://obligement.free.fr
  • »04.12.10 - 05:51
    clr666
    Posts: 86 from 2008/7/8
    FUSE - free unix zx-spectrum emulator does not started with 15.1 becouse illegal instruction in Log Server.
    _______________
    wintel free
  • »04.12.10 - 06:24
    Ok, looking at it.
  • »04.12.10 - 08:45
    Yomgui
    Posts: 348 from 2004/8/31
    Is this release compatible with v14.0 about SDK?
    To know if I need make a PyGame release or not.
    Has someone tested a pygame game with it?
    And now... next project!
  • »04.12.10 - 09:47
    Uploaded version 15.2:
    http://www.amigasoftware.org/test/powersdl_152.lha
    Fixed joystick handling which was broken due to GCC bug. But I still cant get FUSE running. It crashes right after windows is opened. I cant see references to powersdl.library in a crash log.
  • »04.12.10 - 10:07
    @Yomgui
    Havent tested with a pygame but v15 is compatible with v14 SDK. V15 just crashes more often ;)
    [ Edited by itix on 2010/12/4 14:08 ]
  • »04.12.10 - 10:08
    Posts: 12572 from 2003/5/22
    Ardentryst works with powersdl.library v15.2.
  • »04.12.10 - 11:25
    Divinity
    Posts: 532 from 2009/9/8
    @itix
    very good  :-)
    Problems with "the battle for wesnoth" and "Giana's Return"
  • »04.12.10 - 16:52
    SixK
    Itix, Version 15.2 is far better.
    I have some small graphical problems in Meritus
    Legend of Edgar crash at start and freeze Morphos.
    Hits and crash with Zelda3T
    SixK
    [ Edited by SixK on 2010/12/4 23:21 ]
  • »04.12.10 - 21:10
    Okay, looking at those. Seems switching to GCC4 caused more problems than solved.
  • »04.12.10 - 23:55
    _DaNi_
    this version library itix, don´t load images (png and jpg)
    now for example, openbor work, but with no GFX, only a black screen
  • »05.12.10 - 18:49
    SixK
    Itix, will there be a new PowerSDL 15.x release soon ?
    How about creating a new PowerSDL 14.x version compiled for gcc 4.4.4 with few bugs corrections/new features ? (I suspect a bug in rwops that may lead to crash with some SDL_Mixer functions, A support for users native keyboard would be appreciate to avoid to have to swith to american keyboard when playing some games, other various problems if there are some)
    SixK
  • »06.04.11 - 16:46
