Uncompress windows .exe files
  • TGR
    TGR
    Posts: 100 from 2009/10/26
    I've had a quick search but could'nt find anything. is there a program that will allow me to extract self extracting windows archives?
    Mini Mac G4 1.25, 1gb ram, 40 gig hdd, Registered Morphos 2.6.
  • »24.02.11 - 08:22
  • JJ
    JJ
    Posts: 147 from 2010/7/7
    I assume you mean self extracting ZIP files.
    Normal windows exe would need windows
    We don't stop playing because we grow old; we grow old because we stop playing. - George Bernard Shaw
    Xbox Live: S0ulA55a551n2
  • »24.02.11 - 08:40
    Posts: 848 from 2007/10/23
    XAD does support WinZip MS-EXE but not every variant.
  • »24.02.11 - 15:56
    Posts: 3336 from 2003/3/5
    You need to know which compression format it is. unrar should be able to extract rar exes, unzip should be able to extract zip exes.
  • »24.02.11 - 15:59
