little bug in ANR ?
    Simon
    Posts: 809 from 2008/7/6
    Does someone else have this same problem as I have while playing an audiocd ? The arrows to switch forward (or backward) for another song don't work with me.
  • »30.12.10 - 08:29
    Simon
    Can someone put an audiocd in his powermac and test it with ANR ? I can't select the next or previous song.
  • »04.01.11 - 09:45
    xyphoid
    Posts: 870 from 2008/7/11
    I don't usually use ANR and this is probably why too, anyway it just skips back and forth to the only first two tracks. I had to add the tracks to the play list (recent, then go from there
    actually..it does work once files show up from the media library, but not sure if that's what you are looking for gui ver 2.102, ANR ver 4.696 (08.20.28)
    [ Edited by xyphoid on 2011/1/4 16:57 ]
  • »04.01.11 - 19:50
    Simon
    I just want to put in a cd, and skip the song I do not want to hear... I now use "songplayer" for that.
    I tried different GUI, but problem is still there.
    Maybe I should go for AmigaAmp .... or doesn't that work with MorphOS ?
  • »05.01.11 - 10:00
    Posts: 12572 from 2003/5/22
    It does. And most recent version even has a workaround for a MorphOS incompatibility present in prior AmigaAmp version(s).
    http://www.amigaamp.de/board/viewtopic.php?t=169
  • »05.01.11 - 14:12
    Jambalah
    Posts: 820 from 2008/3/30
    Or maybe you can use Amigazeux CD Player too :)
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »05.01.11 - 15:02
    Simon
    I can't get AmigaAMP to work ... I did copy the directory to my harddrive, also put the Powerup-engine, in the engine map. And all it does is saying "INIT" and I can't even close it.
  • »16.01.11 - 17:37
    Posts: 903 from 2003/3/4
    AmiNetRadio is a shoutcast and mp3 player. Playing CDs was added as an afterthought, so no great effort was put into getting it right. You should use some other software.
  • »16.01.11 - 18:01
    Jambalah
    Check if the tooltype "NOOS4" is activated, else you won't be able to use equalizer and playlist. I don't know if this can block all, since here it doesn't happen.
    AmigaAMP can plays .wav tracks from a cd but with no equalizer effects...
    I set the engine on "Autodetect" and here works with no issues.
    Pegasos II 1 ghz
  • »16.01.11 - 18:10
    Simon
    I now use Mplayer. I test some more when I have time.
    [ Edited by Oepabakkes on 2011/1/17 15:56 ]
  • »17.01.11 - 12:55
    xyphoid
    you mean after all this you hadn't even used mplayer? I thought you just had a anr preference or something, mplayer for morphos is like the best port of the software :-D
  • »17.01.11 - 13:11
    Simon
    I did have Mplayer, but I always liked winamp style with skins and as such. Well time to kick it out I guess.
  • »17.01.11 - 15:22
