ImageFX 4.5 Studio
    bash64
    Posts: 974 from 2010/10/28
    ImageFX will not install in 2.6.
    I just got my brand new copy in and it is incompatible with the current installer.
    Anyone else have this issue or a workaround?
  • »19.11.10 - 21:19
    Posts: 1353 from 2004/2/8
    I didn't try IFX, but sometimes installer scripts work better with installer from AmigaOS 3.x. No need to replace the MorphOS one, just right-click, "open with" and choose the 68k installer.
  • »19.11.10 - 21:30
    magnetic
    Posts: 2129 from 2003/3/1
    Hmm weird, it used to straight install on morphos 1.x.. kermit made sure of that.. can you run a log utility and tell what is says?
    If you ordered it from Nova Design, call them up i'm sure they will help. Or from the dealer you got it maybe?
    [ Edited by magnetic on 2010/11/19 21:59 ]
  • »20.11.10 - 00:26
    bash64
    Problem solved.
    I opened it with the original 3.1 installer.
    You also have to switch it from a NOVICE install INTERMEDIATE or you cannot see all of the things that can be installed inlcuding the Power Station and extras.
    I just joined the ImageFX yahoo group to get some basic help.
    The effects it does do are high quality.
    I'd like to find a CD full of good quality effects to add on to it.
    I was told I could perform batch operations but I do not see how yet.
    I need to mass convert ebay pictures by resizing them.
    There are also no thumbnails when browsing jpegs.
    I worked out the prefs to use 1440x900x24bit and I got the thing to print to my laser printer.
    It'd be nice if it could scan from my usb scanner.
    I cannot get even SCANdal to do that.
    Still got PhotoGenics to learn also.
  • »20.11.10 - 02:42
    Posts: 2213 from 2003/2/24
    I'd say ShowGirls (older version included in MorphOS) would be the best for that. It has good basic options for image processing and batch converting.
    ShowGirls has that too ;) It's just a lot more comfortable for image processing in many cases (especially photo handling) than traditional full featured painters/processors.
    I'd recommend ArtEffect too. I have occasional needs to process and modify images and while I'm not pro with any of the programs, I find ArtEffect to be the easiest to get the job done as I want.
  • »20.11.10 - 05:54
    As far as I remember you need to use "AutoFX" for that.
  • »20.11.10 - 05:59
    Posts: 3297 from 2003/3/5
    @bash64
    IFX will not be able to generate thumbnails under MorphOS 2.0+. This is a known issue with a library name conflict.
  • »20.11.10 - 08:04
    Posts: 2562 from 2003/2/24
    Hmmmm, I suspect that would be "thumbnails.library" ?
    Shouldn't it be possible to rename the IFX library of the same name and than use a HEXEditor on the main binary to change any string to "IFXthnails.library" ?
  • »20.11.10 - 08:37
    DoctorMorbius_FP
    Posts: 315 from 2004/2/13
    The library problem has been removed. MorphOS library now is called "thumbnails.library", while ImageFX one is called "thumbnail.library".
  • »20.11.10 - 12:38
    bash64
    Well,
    I am a little disgusted. The first time I tried showgirls it acted like crap and I couldn't even get it to display anything. I just ran it and found out it has everything I needed. I just wasted $80 on ImageFX. Alas.
    I guess I'll keep ImageFX until I can learn what it can do. Perhaps it si way more advanced.
    In the end I might sell ImageFX.
  • »20.11.10 - 16:06
    Is this a fix that you did yourself with a hex editor as suggested in the previous message, or has a change been made in a later version of MorphOS to fix the conflict without the need for user intervention?
    I just tried to install my ImageFX4.5 Studio, but can't because the CD is barely readable (probably a slight scratch), but if I can get it resurfaced so it can be read reliably, I had planned on trying to install it again.
    [ Edited by amigadave on 2010/11/20 10:15 ]
  • »20.11.10 - 16:07
    Golem
    Posts: 766 from 2003/2/28
    The fix is mentioned in the release notes for MorphOS 2.1.
  • »20.11.10 - 18:39
    Thanks for the clarification, I only asked after Jacek wrote that it would not work. He must have forgotten, or never been made aware of the fix that was done in v2.1.
    I hope my disc can be fixed (if it is only a scratch causing the problem) so I can get it installed this week.
  • »21.11.10 - 01:34
