server apps
    GMKai
    Posts: 256 from 2003/4/7
    i would like to know what server-apps are available for morphos:
    ftp: rc-ftpd
    feel free to add entries to the list
  • »05.11.03 - 19:44
  • Targhan
    Posts: 2833 from 2003/2/8
    I like the concept of the ARexx webserver. I don't know what all services it provides, if it's stable, or if it's secure. Still, I would like to know this stuff. I would love to have the opportunity to speak with the author of that system ;-)
    :idea:Targhan
  • »05.11.03 - 21:07
    Posts: 979 from 2003/6/28
    could be nice too a fast http server that supports arexx as scripts, and make your portal in arexx instead of php, and that be fast and not fails :)
  • »06.11.03 - 02:17
  • Targhan
    @timofonic
    ARexxZone! ;-) Powered by PPC ARexx!
    :idea:Targhan
  • »06.11.03 - 02:19
    DJBase
    Posts: 745 from 2003/4/6
    ARexx server is nice thing. Check my sample under
    http://djbase.homeip.net
  • »06.11.03 - 06:04
  • Targhan
    DJBase:
    You should submit your site to the MDC! :-) It would make a great entry.
    :idea:Targhan
  • »06.11.03 - 15:37
    Wishmaster
    Posts: 342 from 2003/6/29
    A fast and reliable httpd with CGI and ARexx support is NCSA httpd.
    You could regard it as a lean streamlined Apache.
    Even in 680x0 mode it is working very fast.
    If I could get down to some serious programmation I could even do a MorphOS native port, but the 680x0 version is working good enough.
    And certainly all AmigaOS 680x0 servers should be working on MorphOS as well.
    Pegasos PPC
  • »06.11.03 - 22:33
    cAHVA
    Posts: 28 from 2003/2/24
    I saw Apache and PHP ports in some place(for MorphOS and 68k).. There was alot of other useful ports too... Unfortunately I have no time to check where they could be found :-(
  • »07.11.03 - 08:36
    DJBase
    I got no apache port working on MOS. Seems to be all dirty and quick ports.
  • »07.11.03 - 09:50
    tokai
    Posts: 1289 from 2003/2/25
    morphos native apache works nice here (only encountered a crash while accessing external SQL databases). I also downloaded the thttpd port for morphos... but didn't had time yet for testing it, as long apache does the job: e.g. i have running zuul (local php interface for mldonkey) here.. works very nice. Also my homepage works well with it (see link).
    also samba server works here w/o problems (68k version).
    if you have problems with apache or other GNU/BSD etc. ports then install the mos sdk.
  • »07.11.03 - 11:27
    GMKai
    hserv is my choice even braindead people can configure this one.
    ftpd of choice is rc-ftpd, even when accessing the ftp-pages with ibrowse is impossible.
    next step would be something that could support one when creating html-pages.
  • »22.11.03 - 12:34
    DJBase
    I can access my rc-ftpd with Ibrowse 2.3 on local.
  • »22.11.03 - 12:55
    GMKai
    what are your settings within rc-ftpd and ibrowse then?
  • »23.11.03 - 09:03
