OWB and Arabic text ?
  • pOS
    pOS
    Posts: 220 from 2003/11/14
    Hello,
    I wonder if anyone has been successfull in viewing text written in Arabic letters using OWB 1.9 ??
    I copied several Fonts to SYS:Fonts
    When OWB is started it tells me that it is is updating its font data.
    But still no Arabic letters can be shown, instead there are ? marks or empty spaces.
    I tried several free Arabic fonts. And yesterday also Arial Unicode MS. Its a font from Win XP sized 23 MB (!) and it definately contains all arabic letters !
    Maybe its just not a matter of installing the right font ?
  • »07.10.10 - 08:53
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    I haven't tested arabic fonts. There could be several reasons to fail though:
    - in tab/window titles, there's no hope to have them displayed. MorphOS GUI doesn't support unicode, and arabic can't really be converted to classic charsets.
    - in webview, if the text appears invisible, it's probably because arabic has to be rendered through a "complex rendering" method that is not implemented in cairo font backend. I might try to see what it looks like when disabled, but i fear it won't be too good (assuming it even works at all). Implementing the complex rendering mode implies switching to pango font backend, which could be possible, but i fear some speed penalties with it (and it also needs some work to get rid of gdk deps).
  • »07.10.10 - 11:41
    Posts: 847 from 2007/10/23
    You can see the problem in wikipedia:
    Hebrew works (right to left, 1 case)
    Arabic fails (right to left, 4 cases)
    Another feature request:
    Safe save of bookmarks.html,
    I've lost the file two times because of full volume :-(
  • »07.10.10 - 16:33
  • Fab
    Fab
    I wrote a workaround to avoid complex rendering for arabic and other cases giving issue (like http://www.mentor.com), and it displays something, at least (that's with the default webcore fonts, nothing more was needed).
    But this workaround obviously means ligatures are ignored. Better than nothing, I guess.
    Using Pango might still be an option, but it needs more investigation.
  • »07.10.10 - 22:43
    Posts: 12558 from 2003/5/22
    Thanks for addressing the issue mentioned there. Seems my worry that you'd ignore it were unfounded ;-)
  • »07.10.10 - 22:54
    samo79
    Posts: 87 from 2003/7/26
    Arabic language should work, almost they works correctly in OWB 3.27 with latest ICU Data (on AmigaOS4)
    BACK FOR THE FUTURE
    http://www.betatesting.it/backforthefuture
  • »09.10.10 - 18:56
  • Fab
    Fab
    My guess is that OS4 port also enforces the simple codepath, considering that http://www.sand-labs.org/owb/browser/trunk/BAL/Fonts/WebCore/AmigaOS4/BCFontAmigaOS4.cpp
    DrawComplexText is unimplemented.
    [ Edited by Fab on 2010/10/9 23:23 ]
  • »09.10.10 - 19:16
    samo79
    Don't feed that old commits, they are too old as Joerg stop to commit his changes at a certain point (more or less 1 year ago)
    Our latest version is based to Sand-Labs's revision 1466 (not the very very latest but not too old !)
    BACK FOR THE FUTURE
  • »09.10.10 - 19:25
  • Fab
    Fab
    Yes, but i doubt the DrawComplexText is implemented anyway. But that's "fine" to fallback to simple mode. It's better than invisible text for sure. :)
  • »09.10.10 - 19:33
    samo79
    Sure, expecially for me that i need Arabic from time to time :-D
    BACK FOR THE FUTURE
  • »09.10.10 - 19:37
  • pOS
    pOS
    I heard that there is an OWB version 1.11 ? Does it contain already some changes to support Arabic text or "just" other changes ?
  • »11.10.10 - 13:47
  • Fab
    Fab
    1.11 will have that workaround, but it's not released yet. If you absolutely need it, i can send you the test version, though.
  • »11.10.10 - 15:56
