SFSDoctor Warning
    osco
    Posts: 680 from 2009/10/20
    Warning
    The selected disk is currently being used by other
    applications(there are active locks on this disk)
    It is strongly advised to quit all these applications
    before performing any operations.
    Continue Abort
    Welcome to SFSDoctor - The Disk Recovery and Repair Suite
    [09:35:46] Checking drive DH2.
    [09:35:46] Checking root blocks
    [09:35:47] Ok
    [09:35:47] Checking admin space containers
    [09:35:50] Ok
    [09:35:50] Checking node containers
    [09:35:50] Ok
    [09:35:50] Checking directory tree and files
    [09:35:51] Ok
    [09:35:51] Checking configuration block
    [09:35:51] Ok
    [09:35:51] Checking bitmap blocks
    [09:35:52] Ok
    [09:35:52] Filesystem structure is correct
    [09:36:47] Saving activity log to file Work:SFSDoctorLOGSystem
    Checking the system disk that is not a valid dos disk?
    (From the upgrade wizard) :-?
    It appears from SFSDoctor that the filesystem structure is correct?
    Has the Installation Wizard lost his WAND? :-D
    [ Edited by osco on 2010/7/6 10:23 ]
  • »06.07.10 - 11:15
    Golem
    Posts: 766 from 2003/2/28
    And if you mount your boot.img (HFS) partition? Can you write to it?
  • »06.07.10 - 11:49
    osco
    Yes saved a text file to boot.img(HFS) partition
  • »06.07.10 - 12:00
    Golem
    Ok, can you explain why you started this thread then?
  • »06.07.10 - 12:23
    Piru
    Posts: 624 from 2003/2/24
    Ever considered that the "not a valid DOS disk" errors might be coming from the MorphOS 2.5 CD (it is the system disk when you boot the MorphOS CD)?
    You can do this to verify the CD:
    1.> cd MorphOSBoot:
    1.> md5chk MD5SUMS GIVEUP
    The last line of the output should be:
    Docs/ModeEdit.pdf: OK
    [ Edited by Piru on 2010/7/6 19:14 ]
  • »06.07.10 - 13:06
    osco
    Magnificent :bloons: :bloons:
    It should be mandated that all check their Installation CD.
    The amount of work that went the OS is staggering,,
    Needless to say all was ok with the installation disk.
    Somewhere My system and the WIZARD part company????
  • »06.07.10 - 19:34
