UAE4All rc2, new features
    BalrogSoft
    Posts: 171 from 2006/10/6
    Hi.
    I made a new version of UAE4All, based on the last sources of Chui,
    this version has new features, like savestates, emulated joystick, and
    the changes i made on previous version, such as enable/disable status bar.
    Download:
    Bin: http://www.amigaskool.net/download/uae4all_morphos.lha
    Src: http://www.amigaskool.net/download/uae4all_morphos_src.lha
    Balrog Software - AmigaSkool.net
    Mac Mini - MorphOS 3.8 - G4 1.5Ghz - Ati 9200 64 Mb
    Efika - MorphOS 3.6 - Ati 9200 64Mb - 80 Gb HD
    Amiga 1200D - OS 3.9 - Blizzard 603e/240mh
  • »20.06.10 - 19:44
    _DaNi_
    Posts: 154 from 2010/5/4
    great :)
  • »21.06.10 - 06:27
    amyren
    Posts: 219 from 2010/5/15
    Just did a quick test here and it runs quite well, tested on the game Volfied. Joystick worked fine also.
    However my kick.rom file from my E-UAE installation did not seem to work so well. But my kick 1.3 file worked.
    But are the docs included a bit outdated. In the readme file(AmigaOS drawer), it refers to the file UAEWB, and to a GUI which uses MUIREXX.
    I only can get to the GUI where you can select image file, run, quit and a few more options. Are there some more advanced configuration options available in another GUI, or must we use command line arguments for this?
  • »21.06.10 - 08:25
    BalrogSoft
    Yes, docs folder wasn't updated, it's a copy of original docs from UAE4all of Chui, and docs refers to original UAE. Some features are deprecated, UAE4all is a strip down version of UAE.
    About the GUI, i want to make a MUI gui to replace the original, and it could have more emulation options, like emulation memory, drawing mode (with a resolution of 320x240 some games don't show all the screen, and it must be rescaled to 320x240), and other features.
    I made public this version because it have a lot of improvements on speed emulation (thanks to Chui), savetates and emulated joystick. I don't have a lot of time to develop at home, but next version will be focus on GUI, and Fame 68k core emulation (which should works even better) that actually doesn't works on big endian platforms (not fame core, the uae4all emulation with fame core).
    [ Edited by BalrogSoft on 2010/6/22 0:26 ]
  • »21.06.10 - 09:22
