Adding to 'Utilities' Menu
    igracki
    Posts: 471 from 2003/2/24
    Few Suggestions from beworld:
    - not possible to move menu / submenu and element Up and Down into the list
    This is already possible, check the "DnD sort? checkmark!
    But, then you have to take care yourself that you don't move a menu with submenus into a submenu f.e.
    Because you only can have menu/submenu/item, a submenu within a submenu isn't allowed by the OS.
    - have a option to "AutoSave on quit"
    This is in the prefs menu, which means that the prefs will be autom. saved on quit.
    But nothing will be save atm, I could add remembering the "DnD Sort" checkmark...
    You mean to save the autosave the menus, right?
    - have a option Save - Save As
    Ok, I could add a "Save" w/o asking for filename, if a filename is already specified.
    - options CLI to lauch with shell - exemple CRABUM -QUIET SYS:test.rexx
    Ok, I'll add filename specifying on startup.
    But what for should the "QUIET" option be?
    If you want to see the icon, just re-download the archive, I just updated it;)
    [ Edited by igracki on 2010/2/26 14:40 ]
  • »26.02.10 - 11:33
    beworld
    Posts: 685 from 2010/2/10
    Lauch your application in silent mode on shell....
    Thank for your response.
    @beworld
    My MOS ports
  • »26.02.10 - 14:19
    igracki
    a new version is ready for download!
    Here is the history:
    New: Added shell args support, you can now specify a filename, which will be loaded
    at startup
    [suggested by beworld]
    Fix: If you load a file where no entries were found, a warning req appears
    Chg: Renamed Menu/Project/Save Menu/Project/SaveAs
    New: Added Menu/Project/Save to save current project
    Fix: Fixed a read from NULL
    [Thx to Marcin Kornas]
    New: The name of the current project is now displayed in the window title
    New: If you changed the current project a "*" is displayed after the name in the window title
    New: The state of the "DnD Sort" checkmark is now remembered
    Chg: The "Shortcut" now can only be one char instead of a string, because only one char is
    supported by the Ambient/OS
    Fix: The "Shortcut" wasn't saved!
    New: New catalog strings:
    MSG_Warning_NoValidEntriesFound, MSG_Menu_Project_Save, MSG_Menu_Project_SaveAs
    also added underscores to MSG_Req_Ask_ButtonsYesNO and MSG_Req_Ask_ButtonsYESNo
    @beworld:
    a QUIET option isn't needed, cause CRABUM doesn't outputs anything, or you can use ">NIL:"
    [ Edited by igracki on 2010/2/26 23:03 ]
  • »26.02.10 - 20:01
    beworld
    ok thank for this version.
    My but for the QUIET Option is to lauch the new menu with startup-sequence and not with the WBStartup....
    Sorry for my english.... :(
    My MOS ports
  • »27.02.10 - 07:28
    igracki
    by beworld on 2010/2/27 10:28:00
    I think I still don't understand you;)
    Do you want to start CRABUM in the user-startup (not startup-sequence)? Why?
    Or do you want to install the created menu from user-startup?
    Then you have to simply add this line to the user-startup:
    rx rexx:menus.rexx
    If you saved the created user menu as "rexx:menus.rexx".
    My english is also not better8-)
  • »27.02.10 - 11:16
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    It won't work in user startup, since ambient isn't started at that point. :)
  • »27.02.10 - 11:26
    beworld
    rx rexx:menus.rexx
    ok... with RS it's work... sorry....
    My MOS ports
  • »27.02.10 - 14:01
    igracki
    Upps, ok, you're right;)
    Then WBStartup is the right place.
    Maybe Ambient could automatically load a default menus.rexx if it exists?
    I think SYS:Prefs/Ambient/menus.rexx would be a good place!
  • »27.02.10 - 16:24
    igracki
    New v1.2
    28-Feb-2010 v1.2
    Chg: If you add a new menu/submenu/menuitem it will be set as the active entry
    New: The initial drawer when you load/save a project is set to SYS:WBStartup
    [suggested by Daff]
    Chg: Removed the MSG_Menu_Prefs_MUI locale string, cause its the same in all languages
    New: If the current project was modified and you select quit, a requester asks you
    if you want to save before quit, quit w/o save or cancel
    Chg: Added a "..." to MSG_Menu_Project_Quit, because if the current project was modified
    a requester appears
    New: Added some more localized strings
    New: The save requester is now in SaveMode
    (But I think today its no difference, previously a SaveMode-Req doesn't supported doubleclick)
    New: You can now drop icons/files on CRABUMs window to load a usermenu!
    New: If you want to load a new project, but the current has been changed, a requester appears
  • »27.02.10 - 22:21
    igracki
    New v1.3
    3. M?rz 2010 v1.3
    New: Added some new strings
    Chg: Changed the "Save..." button to act as "Save" not as "Save as"
    New: Added a new menuitem "Project/New..." to start a new project
    if you changed the current project but didn't saved, a requester pops up
    1. M?rz 2010
    Chg: To load a project you can drop it on the listview now, previously you could
    drop it everywhere in the window
    New: You can now add an item by dropping a file or directory onto the "Add..." group.
    [suggested by stefkos]
    New: If you drop a directory, the "comType" is automatically set to INTERNAL
    and the "command" is set to open a new lister with the directory!
    New: if you drop a file, but didn't have add a menu before, a menu gets added automatically
    New: a dropped files "comType" is set to INTERNAL and the "command" is set to "loaduri <file>"
    so the file is handled by ambient
    New: added a helpbubble to the listview and the add-group which says what will be done
    with the dropped files
  • »03.03.10 - 20:22
