Aweb much faster then Ibrowse
    amiga4001
    Posts: 454 from 2006/11/16
    I just had Aweb going again after some tinkering.
    I used Ibrowse for a long time but no I notice a great speed
    up compared to Ibrowse.
    Why is this?
    Also even the newer Ibrowse version crashes badly at ebay sites.
    Is there a way to emulate another platform and use an other browser?
    In a usable way that is.
    It just is for these occasions where you can't use Ibrowse,Aweb.
    And Sputnik isn't that usable right now for browsing too Beta..
  • »17.05.07 - 06:06
    weiseb
    Posts: 215 from 2003/3/29
    I neither have a problem with (german) ebay and ibrowse nor does Aweb seem remarkable faster here (but I havent measure it).
    Are you using IBrowse 2.4 and the morphos-native JScript library?
    Maybe you can provide some websites with problems/speed difference for comparison.
  • »17.05.07 - 07:19
    diezi7
    Posts: 167 from 2005/7/25
    Both IBrowse and AWeb work fine for me.
    Aweb is slightly faster, but Ibrowse has much
    more options, it?s 68K and Aweb has native MOS port.
    But IBrowse in particular, hangs on ebay.com on
    my setup too
    Pegasos II G4 (not working)
    Powerbook G4 1.0 15"
  • »17.05.07 - 08:04
    amiga4001
    Yes ebay.de in my case hangs ebay.
    Or http://www.motozoom.nl try to enter the webshop.
    As Macemulation a possible solution for a browser?
    Or to slow?
  • »17.05.07 - 08:10
    Get27
    Posts: 90 from 2004/8/23
    Hi !
    I've got same problem with ibrowse with or without flash plugin. I use sputnik to surf on ebay site.
    I think it's mui class problem, i've got lot of disorder in my MOS partition.
    [ Edited by Get27 on 2007/5/18 1:33 ]
    PowerMac 3.5, G4 1.0GHz DP, 1GB ram, 80GB HD + NAS, Radeon 9600 128MB Mac, 1680x1050
    PowerMac 7.3, G5 2.3GHz DP, 4GB ram, 160GB HD + NAS, Radeon 9800 128MB PC, 1680x1050
    Amiga 500+, Vampire 500v2+, HxC Floppy
  • »17.05.07 - 22:32
    judas
    Posts: 175 from 2005/1/14
    I use Aweb, because it's blazing fast and stable.
    Ibrowse locks my system shortly after start or when rezising the window.
    I really wonder, why Ibrowse (Demo) is that unstable on my system ...
  • »18.05.07 - 04:58
    Wishmaster
    Posts: 342 from 2003/6/29
    Because you did not apply the trance update.
    Pegasos PPC
  • »18.05.07 - 21:00
    Framiga
    Posts: 363 from 2003/7/11
    and IB demo have 2 connections only. Hence you feel it slower than AWeb thats a no, no go!
  • »19.05.07 - 10:21
    judas
    @wishmaster
    Thanks a lot !! After using trance-update, ibrowse works stable.
    Although I still think, aweb is my favourite, I must admit, that ibrowse works better on sites with lots of special features.
  • »20.05.07 - 13:38
    stephen_robinson
    Posts: 746 from 2007/4/22
    Sorry to drag up a thread from the depths, but it seemed slighty better than starting on afresh.
    But I've just downloaded aweb from http://www.greyhound-data.com/gunnar/aweb/index.htm?page=downloads
    When I try to run it "Can't open window.class" , I've had alook on Aminet and the interwebs, but I can't seem to find it, Where do I find it these days?
    "The snapshots on this site will run out of the box.
    Just decompress the archive, start Aweb and surf."
    Wonder if he actually, like you know, tested it...
  • »23.02.10 - 19:31
    Golem
    Posts: 766 from 2003/2/28
    Grab ClassAct from Aminet and install it.
  • »23.02.10 - 20:15
    stephen_robinson
    Working! Thanks!
    Edited to add, well it did for about 3 seconds before freezing up the computer, I shall look into this...
    [ Edited by stephen_robinson on 2010/2/23 22:37 ]
  • »23.02.10 - 20:33
    Posts: 423 from 2005/4/9
    you need classact to run aweb.
    http://aminet.net/dev/gui/classact33.lha
    edit: i should use the refresh button before posting a reply...:)
    [ Edited by sadddam on 2010/2/24 0:16 ]
    zx.spectrum@3.5
  • »23.02.10 - 21:15
    xyphoid
    Posts: 870 from 2008/7/11
    Posted with OWB Ver.1.6.1
  • »23.02.10 - 23:23
    trotter
    Posts: 106 from 2010/1/14
    Newer version of aweb here but its 68k only but worth a look, not tested it yet on the mac mini.
    http://opi.kilu.de/AWebTest/AWeb-04.10.2009.lzx
    Martin N
    Running MorphOS v3.18 on Mac mini 1.5GHz 64meg VRAM,1gig ram.
    Palm T3 pda along with pixel 4a GrapheneOS smartphone. Updated August 2023
  • »24.02.10 - 20:38
    Henes
    Posts: 507 from 2003/6/14
    Working! Thanks!
    Try the (probably) only really fully working AWeb PPC version:
    http://bigfoot.morphos-team.net/files/
  • »25.02.10 - 08:04
    Posts: 2220 from 2003/2/24
    Disabling javascript makes IBrowse lot faster and stable (I only enable it on sites really needing it (site prefs for regular sites or quick prefs for occasional needs)).
    Someone was also having slowness with IBrowse because of the connections number or memory cache settings. Can't remember which one, but it was configured for pretty lowend needs, which isn't good idea on ultra fast MorphOS systems ;)
  • »25.02.10 - 13:37
    Velcro_SP
    Posts: 929 from 2003/7/13
    [ Edited by Velcro_SP 15.05.2011 - 09:06 ]
    Pegasos2 G3, 512 megs RAM
  • »26.02.10 - 12:26
    Korni
    Posts: 473 from 2006/2/23
    1,2. Nowhere, AWEB homepage doesn't exist ATM unfortunately.
    3. Do you mean Classact stuff included with AWEB? No idea.
    4. Probably yes, but old versions crash with 3Dlayers. I use my own build (from Feb 12 2009) which works quite ok but w/o SSL, it doesn't feel much diffrent though.
    [ Edited by Korni on 2010/2/26 21:37 ]
  • »26.02.10 - 18:33
    Posts: 12572 from 2003/5/22
    > 1) Where is the most current version of AWeb for MorphOS?
    http://www.amiga-news.de/en/news/AN-2007-08-00005-EN.html
  • »26.02.10 - 20:22
