PolyOrga and ttengine.library
    insurgent
    Posts: 64 from 2007/7/8
    I have installed PolyOrga 1.07 which requires TrueType engine library. I have downloaded version 7.2 for MOS but what to do with it? How do I install the library? Is it just a matter of copying ttengine.library to System/Libs? Or do I also have to set environment variable somewhere?
    Thanks!
    Registered MOS 2.7 + Pack Ultimate 1.6.2 running on:
    Power Mac G4 FW800 1.42GHz 2GB / Radeon 9000 Pro 128MB / SB Live! / NEC USB 2.0 / SuperDrive
    Mac Mini G4 1.5GHz 1GB / 64MB VRAM / SuperDrive
    Dell UltraSharp 2407WFP 1920x1200
    PowerBook G4 ready :-)
  • »21.02.10 - 09:57
    Sprocki
    Posts: 131 from 2005/2/23
    In case of MorphOS 2.4, MOSSYS:Libs/ contains ttengine.library already. You do not have to configure it. Just get PolyOrga 1.16 from http://polymere.free.fr .
  • »21.02.10 - 10:31
    insurgent
    Thanks for link to the latest version - it works fine!
  • »21.02.10 - 11:11
    jcmarcos
    Posts: 1178 from 2003/3/13
    insurgent wrote:
    it works fine!
    Mmmm... If only it synced with mobile phones... What would be easier, hacking Microsoft's ActiveSync, or making MorphOS run on a mobile phone?  :-)
  • »22.02.10 - 09:08
    matt3
    Posts: 770 from 2004/2/10
    @jcmarcos
    I agree PolyOrga would gain value if I could use it with my smartphone.
  • »23.02.10 - 10:47
    jcmarcos
    Indeed, and it was mentioned before. But the starting point is not obvious, as first the phone has to be "seen" from MorphOS, maybe as some kind of devide, through Poseidon. Surprinsingly, there's something there.
    But then, you'd have to research about Microsoft's ActiveSync. There's a certain synce and multisync, though.
    The thing is, nobody has asked for this yet, and MorphOS and WindowsCE based phones exist since a long time. No interest at all? It could be fun...
  • »23.02.10 - 11:08
  • Bounty Manager
    insane
    Posts: 68 from 2003/5/20
    Would be really nice to sync my Palm Pre with Poly Organiser !
  • »23.02.10 - 15:52
