Mac OSX Leapord on Pegasos
    magnetic
    Posts: 2129 from 2003/3/1
    Hi Guys
    I know some of you are running MOL (Mac On Linux) with either Molk or MOL on debian or PegXMac is it possible to run 10.5 on Pegasos>?
  • »20.01.10 - 20:35
    kickstart
    Posts: 227 from 2009/4/28
    I dont own a pegasos, but leopard with a G4 seems not enought, 10.4 runs "smoothly" on a G4.
  • »20.01.10 - 23:27
    magnetic
    kickstart
    I'm running OSX Leapord 10.5.8 on my Powerbook g4 1.25ghz w 1gb ram very nicely!
  • »21.01.10 - 00:46
    Posts: 1102 from 2004/9/23
    Same here. Using Leopard on ibook G4, 1.25 Ghz with 1.25 GB Memory.
    Of course it depends on what you wanna do with it. I mostly use it for NeoOffice, Skype, Chat, Web and some tools like TrueCrypt. Using them all together is of course making the system a little slower, especially when the skype beast is running.
    I can live with it, but as I said. It depends on your needs.
    Compared to a Windows system, which is slow by definition, I never had an problem with it. Which keeps the workflow fast, while Windows starts to annoy me starting from beginning, when tons of virus scanner and of course windows update forces you to slow down, even if you just launched it to print a simple document. :)
    Geit
  • »21.01.10 - 08:21
    jcmarcos
    Posts: 1178 from 2003/3/13
    What the hell is Skype doing that is so complicated?!
    a Windows system is slow by definition
    It depends on what you make it do.
    Antivirus is not part of Windows. As a side note, I never install antivirus on any of my computers, be it Windows or not.
    It's not mandatory, you can disable it.
  • »21.01.10 - 08:43
    CountRaven
    Posts: 566 from 2007/12/10
    For ages I am trying to find a current way to run any version of Mac OS X on my Peg. Wish I could find a kind of guide / tutorial. I know there is one on the Big Pegasos Book I should re check it, but I need more stuff. I even have left a spare partition on the Peg2 for a possible Mac OS X install..
  • »21.01.10 - 10:44
    pampers
    Posts: 1073 from 2009/2/26
    CountRaven: I'm quite lame myself with setting up that kind of complicated stuff like MOL or PegXMac but with mention Pegasos Book it was quite easy to do. Worth of trying anyway.
    MorphOS 3.x
  • »21.01.10 - 11:15
    CountRaven
    @Pampers: Yes I am reading the chapter again. For us who have managed to make the evil 1.4.5 boot on our classic Amiga a PegXmac quest should be more easy hahaha :)
  • »21.01.10 - 11:34
    pampers
    That's nothing else but true my friend :) If you are able to run MorphOS on your Classic Amiga, then you can do anything else.
    MorphOS 3.x
  • »21.01.10 - 14:06
    kickstart
    @magnetic
    Im still thinking 10.4 is faster than 10.5, anyway 10.5 have some "artificial" limit for cancel the installation on determinated cpu?s.
    @geit
    Some people tells about windows 7 run quite well on slow machines, maybe osx is overvalued.
  • »21.01.10 - 14:46
    magnetic
    Count Raven
    Do a search for "Molk" for morphos and read the guide it comes with best way to run OSX on your peg afaik
  • »21.01.10 - 22:42
    _ThEcRoW
    Posts: 298 from 2008/10/27
    A bit off-topic question: WHat is really MOL?. Like aros running hosted on linux?. Or is it booting straight away on his own partition???.
  • »23.01.10 - 12:00
    pampers
    It's really small Linux distribution - MacOS On Linux
    MorphOS 3.x
  • »23.01.10 - 17:28
    _ThEcRoW
    But if its's a linux distribution, how it loads the osx?. It's a virtualized one like vmware on pc?
  • »24.01.10 - 11:48
    Golem
    Posts: 766 from 2003/2/28
    Mac-on-Linux
  • »24.01.10 - 12:35
    Posts: 12579 from 2003/5/22
    No, it's not. It's a Linux program.
  • »25.01.10 - 01:22
