mmsclient why the verbose output?
    osco
    Posts: 680 from 2009/10/20
    Ram:>mmsclient mms//...(url address)
    Downloaded a 5.7mb windows media file in Ram:
    Why the endless output in the shell window?
    Does it end?
    How long does it take to download a 5.7mb file? fast cable connection?
    I closed the shell as it was vomiting yet the media file was there in full
    Correction
    It was not there in full until a time period passed..
    Even though I closed the shell window the process kept going until the fi
    TIA :-)
    The verbose output are the individual packets being transmitted. I waited when the stream of packets stopped and was greeted with congradulations..the length of the stream determines the time/
    [ Edited by osco on 2010/1/18 21:19 ]
    [ Edited by osco on 2010/1/18 21:20 ]
    [ Edited by osco on 2010/1/18 21:33 ]
    [ Edited by osco on 2010/1/18 22:02 ]
    [ Edited by osco on 2010/1/19 8:58 ]
  • »19.01.10 - 00:18
    jcmarcos
    Posts: 1178 from 2003/3/13
    You can make dissapear the stardard output of any command redirecting it to the null device ("NIL:"):
    mmsclient >NIL: mms://...(url address)
    But perhaps, in this case, seeing the output is important, as it seems there's no other way to tell the process has finished.
  • »19.01.10 - 07:42
    Golem
    Posts: 766 from 2003/2/28
    @jcmarcos
    You can usually tell when you are returned to the prompt.
  • »19.01.10 - 10:47
    osco
    My Ambient screen is full of dancing bannanas )
    Got my headphones on and listtening to good vibrations :)
    Got the OWB Browser surfin :)
    Bigtime smilin............. :-D  :-D  :-D  :-D  :-D  :-D  :-D  :-D  :-D  :-D  :-D  :-D  :-D
    Thank-you all
  • »19.01.10 - 11:33
