Mplayer Record Stream Wont Save?
    osco
    Posts: 680 from 2009/10/20
    What are the settings in preference?
    What is the setting
    "Cache Files" used for?
    How do address the entry "Dump Stream To:"?
    Please give an example syntax
    Thank-you
    A reread of Fab's explanation below
    "If you want to use the GUI to record, just select the fullpath you want to record to in that "dump stream" string. Then, in pulldown menu->control, check "Record Stream", and then play your stream normally. You can even enable/disable record at runtime to skip unwanted parts, as long as you started recording before playing the stream.
    From command line, you could do it too (with dumpstream & co), but you couldn't watch it at the same time."
    There is an [b]exact[/b] progression!!!!! First the path Second check record stream Third play stream
    My error in not being able to record was i failed to check the record before the play :-P  :-P  :-P  :-P
    [ Edited by osco on 2010/1/16 14:49 ]
    [ Edited by osco on 2010/1/16 14:56 ]
  • »16.01.10 - 08:56
    pampers
    Posts: 1071 from 2009/2/26
    OSCO: do you really have to open a new topic for any single question? You can ask your questions in Mplayer thread and I'm sure you will get your answer. Don't get me wrong but it looks bit messy, with opening 1 thread to get 2-3 replies...
    [ Edited by pampers on 2010/1/16 11:08 ]
    MorphOS 3.x
  • »16.01.10 - 09:07
    osco
    :-P
    [ Edited by osco on 2010/1/16 14:50 ]
  • »16.01.10 - 09:35
    osco
    3.4.1.?Saving streamed content
     8-)
    [ Edited by osco on 2010/1/16 14:51 ]
  • »16.01.10 - 17:30
    Golem
    Posts: 766 from 2003/2/28
    Ok.
  • »16.01.10 - 17:54
