How do launch snoopium?
    osco
    Posts: 680 from 2009/10/20
    Double click Snoopium Icon ...no tool?
    What would be the shell command?
    Went to aminet and downloaded their version.. size 202.7 kb 03/09/2008
    Morph 2.5 tool size 80.3kb 10/10/2009?
    What size is on your MorphOS 2.4?
     :-D  :-D
    I moved some mcc tools to another draw for ANR My MorphOS System Classes MUI/ Busy.mcc HotkeyString.mcc and NList.mcc Would this cause Snoopium to fail?
    [ Edited by osco on 2009/12/15 9:29 ]
    [ Edited by osco on 2009/12/15 9:38 ]
  • »15.12.09 - 12:08
    Ruud
    Posts: 335 from 2009/2/2
    It should just load by double-clicking the icon.
    It doesn't?  :-?
  • »15.12.09 - 12:13
    Jambalah
    Posts: 820 from 2008/3/30
    Launching SnoopDOS and checking what Snoopium does when launched, you'll notice no tools requests.
    The V1.9 I have in MorphOS 2.4 is 80.3 k.
    On the "Readme" file no tools are specified. Same in the guide.
    A lot of Arexx command, instead.
    Question:
    anyone knows if the ".cd" file catalogs of v1.6 could be usable on 1.9 version?!?
    [ Edited by Jambalah on 2009/12/15 15:39 ]
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »15.12.09 - 12:38
    osco
    How do I know Arexx is ok?
    What shell command will check if RexxMast is mounted?
  • »15.12.09 - 12:41
    Jambalah
    Try to type "rx" in a shell window. Something like "Usage: RX <filename> [arguments]" should appear... =)
    Pegasos II 1 ghz
  • »15.12.09 - 12:56
    osco
    Ty It Does
  • »15.12.09 - 13:09
    Jambalah
    ..well.. I guess you should check something else, too..
    For example:
    "1. Rename rexxsyslib.library present in MOSSYS:Libs/ to, say, rexxsyslib.library_original.
    2. Find the AmigaDOS 3.x version of rexxsyslib.library and copy the file to SYS:Libs/.
    3. Use a text editor and insert the command line RexxMast >NIL: in your s:user-startup file.
    4. Reboot"
    (thanks to kriz in this topic: Topic)
    Pegasos II 1 ghz
  • »15.12.09 - 13:25
    Posts: 1521 from 2003/2/24
    @osco
    It should run directly just by clicking on its icon. Maybe you changed someting on the icon?
    Just type 'Snoopium' in shell.
    Binaries shipped with MorphOS 2 are compressed. Hence smaller size.
    It should not. Snoopium uses only built-in MUI classes.
    @Jambalah
    They should be compatible but you dont get full translation.
  • »15.12.09 - 13:38
    Golem
    Posts: 766 from 2003/2/28
    @Jambalah
    Why would you want to run RexxMast twice?
  • »15.12.09 - 13:38
    Jambalah
    @ Itix:
    Thanks! I was translating and I noticed something is missing.. =)
    @ Golem:
    ..ahem.. can I use the excuse I have the temperature?!? My mistake... sorry =)
    Pegasos II 1 ghz
  • »15.12.09 - 14:05
    Posts: 12572 from 2003/5/22
    > "[...] 3. Use a text editor and insert the command line RexxMast >NIL: in your
    > s:user-startup file [...]"
    "RexxMast >NIL: is already in startup-sequence."
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=6514&forum=3#66262
  • »15.12.09 - 14:10
    osco
    First try at using "quote TOOL" in posting :)
    [quote] [/quote]It should run directly just by clicking on its icon. Maybe you changed someting on the icon?
    How would I check if that was the cause?
    [quote][/quoteJust type 'Snoopium' in shell.
    Shell session:
    Ram Disk: >Snoopium
    Unknown Cmmd
    Ram Disk:> System:
    System:> Tools
    System:Tools>Snoopium
    System:Tools " a blank output"
    System:Tools> LIST
    Ouput is a list of applications in the TOOLS drawer of which
    Snoopium Info 7301
    Snoopium 82277
    Do these above agree ?
     8-)
    [ Edited by osco on 2009/12/16 11:13 ]
  • »16.12.09 - 13:58
    osco
    Opened the Boot CD for MorphOS 2.4 and copied the Snoopium info and Snoopium ans pasted them in System:
    Double clicked onto the Snoopium icon......nothing?
    Going to Aminet and download their version and try :-o  :-o  :-o  :-o
  • »16.12.09 - 15:03
    Golem
    So does it run if you boot from the CD? Which changes did you make to your setup?
  • »16.12.09 - 15:06
    osco
    Didnt boot from the CD. Just opened it and copied Snoopium and its Icon to a drawer on the harddrive ..It did not work :(
  • »16.12.09 - 15:16
    osco
    Just tried to run Snoopium from the Boot CD Dounle click on theSnoopium Icon ....nothing?
  • »16.12.09 - 15:20
    Golem
    Is this when actually booting from the CD, or are you trying to launch it from a possibly corrupted installation? If you have in some way managed to change some system component that Snoopium depends on, it will not matter where you attempt to run it from.
  • »16.12.09 - 15:32
    osco
    Not booting from the CD rather reading the contents of the CD..The Cd will open and display its content
    IF I were to boot from the Cd would it attempt to reinstall the OS?
    The install CD has what options?
  • »16.12.09 - 15:36
    osco
    I hope it was caused by adding moving and or deleting files to get ANR to work? Snoopium was to be the troubleshooter to find errors
    It dont open?
  • »16.12.09 - 15:41
    Golem
    Booting the CD will not force a reinstall, though considering the current state of your system, that is the only thing I can recommend.
  • »16.12.09 - 15:50
    osco
    Perhaps you are right and a reinstall is needed. Strange the one application to troubleshoot is down?
    ty
  • »16.12.09 - 15:56
    Shell session:
    Ram Disk: >Snoopium
    Unknown Cmmd
    Ram Disk:> System:
    System:> Tools
    Does it work if you use SAFEMODE switch?
    Try "Snoopium SAFEMODE" on the shell or add "SAFEMODE" tooltype to the icon.
  • »16.12.09 - 17:26
    osco
    Snoopium still down.
    "Safemode" no help
  • »17.12.09 - 11:25
