Turkish Keymap for MOS 2.4
  • Visitor
  • Hello
    I noticed that MOS 2.4 has no Turkish keymap.
    How can I create a Turkish keymap for MOS2.4 so I am able to type Turkish characters in ISO-8859-9 charset ?
    Thank you...
  • »10.11.09 - 07:49
    Posts: 3336 from 2003/3/5
    See keymaps.lha which contains the MorphOS keymaps. You can use these as a reference to build your own. Just don't ask me what the fields mean :) MorphOS uses adapted / fixed AROS keymaps.
  • »10.11.09 - 08:24
  • Visitor
  • Thanks for the file jacadcaps...
    I am trying to find a reference for creating Turkish keymap but I couldn't find any.. AROS also lacks turkish support..
    I tried converting an old PC105 68K turkish keymap with Wishmaster's keymap editor but it doesn't allow me to change the ISO standard to ISO-8859-9, so some Turkish characters aren't displayed..
    Can anyone help about this ?
    Thank you
  • »10.11.09 - 17:07
    Krashan
    Posts: 1107 from 2003/6/11
    You just have to modify some other keymap. Informations needed are:
    - codepage with unicode mapping (if Turkey uses ISO-8859-9, these data can be fetched from unicode.org).
    - keyboard mapping (which key combination generates which character). Too bad I have no idea about Turkish keyboard mapping.
    Having these data you can modify any keymap and compile the Turkish one.
  • »10.11.09 - 17:54
    Posts: 848 from 2007/10/23
    How about this?
    Aminet
  • »10.11.09 - 21:00
    Seventhwonder
    Posts: 6 from 2009/11/11
    Hello Polluks
    I have tried this keymap, it is the correct keymap however it doesn't select ISO-8859-9 charset when you activate the keymap.
    Is there a way to use the ISO-8859-9 charset when you select this keymap. ?
    In the MOS keymap prefs no ISO standard appears beside Tr keymap..
  • »11.11.09 - 07:40
    Krashan
    @Seventhwonder
    I can help you with the keymap if you tell me the mapping (which key combination produces which character) and help with testing.
    [ Edited by Krashan on 2009/11/11 9:58 ]
  • »11.11.09 - 08:50
    Seventhwonder
    Dear Krashan
    Thank you for your kind reply.
    For Turkish keyboard layout please check the following website.
    This is a standart Turkish keyboard.
    http://www.katpatuka.org/pub/doc/keyboard/trq.html
    Turkish uses ISO-8859-9 standard for characters..
  • »11.11.09 - 10:02
    Krashan
    OK, so I have all the informations needed. I have one question related to the keyboard image. There are 3 characters on some keys. I assume lower character is obtained by just pressing the key. Higher left character seems to be SHIFT+key. What is higher right character? ALT+key? If yes, one specific ALT or any of them?
    [ Edited by Krashan on 2009/11/11 13:13 ]
  • »11.11.09 - 12:12
    Seventhwonder
    Krashan,
    These characters are typed with by holding down Alt Gr (the alt key on the right side of space bar)
    Thank you :)
  • »11.11.09 - 13:03
    jcmarcos
    Posts: 1178 from 2003/3/13
    Little question: Wasn't "Alt Gr" actually "Control" and "Alt"? I think I remember that, with the first AT keyboards (older ones didn't have "Alt Gr")...
  • »11.11.09 - 13:19
    Krashan
    @Seventhwonder
    I've sent a private message to you with a link to Turkish keymap to test.
  • »12.11.09 - 07:24
    CISC
    Posts: 619 from 2005/8/27
    Upper left is accessed with Shift, lower right is accessed by Alt and upper right is accessed with Shift+Alt (ie; Alt activates the alternative char, while Shift activates the upper char, thus Shift+Alt activates the upper alternative character).
    - CISC
  • »12.11.09 - 10:11
    Seventhwonder
    Thanks to Krashan, Turkish keymap is now added to MOS and it is working very well..
    Great stuff :)
  • »12.11.09 - 17:59
